EB008 Quad 7 Segment Display Board examples
Steve001
- Has thanked: 460 times
- Been thanked: 523 times
when trying to open the test files i am getting the follwoing error ?
can anybody advise please
Re: EB008 Quad 7 Segment Display Board examples
Hi Steve,
There are two things you can try.
1) In view, Global options, set the overriding language to English.
2) If That don't work then download the full install of latest version (V4.3.7.63), as the update patch I believe had a bug.
Alternately you could post the flowchart you are experiencing problem with, and I can try it on my PC.
Steve001
Hi medelec,
my flowcode is forced to english as i was getting errors saying " cannot detect language defalting to english"
the files are the ones downloaded from the test files section
will check my version of flowcode later on. I have flowcode 4 and the update
steve
steve
Files you have posted appear to be corrupt. They don't load on my PC either.
So your Flowcode Could be OK.
I have downloaded same examples from:
http://www.matrixmultimedia.com/eblock_datasheets.php
and attached them to this post.
They load OK on my PC
The odd thing is, If they are same files, I wonder why there is a size difference between these two and your two?
For more pratical exaples of 7segment displays see:
http://www.matrixmultimedia.com/mmforum ... 95&p=20772
and
http://www.matrixmultimedia.com/mmforum ... 37&p=20644
These examples use timer0 interrupt to light each LED Component in turn.
and
- 7_seg-fc4.fcf
- (8 KiB) Downloaded 525 times
- 7-seg'88-fc4.fcf
- (8 KiB) Downloaded 509 times
Steve001
mmmm get the same error with those test files matey ?
the link that you gave me is the link that i downloaded them from in the first place
i am using flowcode 4 ver v4.3.7.63
steve
steve
some how files are getting corrupt, after they are saved on your pc.
A virus perhaps?
One very good free anti-virus from Microsoft is called Microsoft Security Essentials. Download from here:
http://www.microsoft.com/security_essentials/
Also gets rid of spyware.
You can see the size difference, Which is concerning.
I have downloaded the same file you did from my previous post, and that loaded fine.
I have heard of some servers changing files as they are saved. You saving directly on to your C drive?
I will leave matrix to help you further, as I don't believe I can.
A virus perhaps?
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
The latest release of the PICmicro variant is "v4.3.8.64". Perhaps using this will solve the problem?
EDIT: ignore this, I made a mistake. The latest available version is the V4.3.7 that you have.
Steve. The odd thing about these files which are all downloaded from the same location is:
Files I uploaded Reported and actual file size = 8K
Files Steve001uploaded Reported = 8K and actual file size = 4.5K
I seem to remember some one else had similar problem, when using a server?
Steve001
i am not using a server as such, but using a nas system called naslite
had no issues with it so far with flowcode they seam to work well together
i have downloaded both files that medelec uploaded to my desktop and if i right click on them they are 8K on disk but 4.5k in size ?
steve
steve
I have sent you the two 7seg demos and the interrupt demo via email given to me via PM.
You can see the size difference (shown within brackets) of files you posted(4.5K) and files I posted(8K)
Yet on your PC they are all wrong size at 4.5K
Have you tried emptying browser cache as steve though it may be that.
Or you could try a different browser.
Steve001
got those thanks, my internet history is set to clear all on exit anyway.
I am using I.E 8 will try wifeys laptop later as she uses google crome.( permision pending )
and let you know how i get on
steve
steve
Steve001
still had problems with ones downloaded using google crome ?
ones from medelec are working fine. .. thanks matey
steve
steve
Your welcome.
Until you can resolve the downloading issue, let me know if you want any more files from this website, and I will forward them to you.
Martin.
Martin.
Steve001
cheers for that . had no isssues before have downloaded a few from the test files page
steve
steve
Steve001
Since removing 64 bit internet explorer 8 and going back to normal internet explorer that issue seams to have gone away .
dont know if that was the issue or not but seams to work now .
steve
steve
