pickit3 parameters
stephan
Flowcode v5 User
Has thanked: 1 time
Been thanked: 2 times
pickit3 parameters
Post by stephan »
Hello ,
I saw one post about the use of Pickit3 talking about compiler options like:
Set the Programmer location to: C:\Program Files\Matrix Multimedia\Flowcode V4\Tools\PICkit3\pk3cmd.exe
Set the Programmer parameters to:-P%p -F%f.hex -E -M -Y
I wanted to know , where could i find datsheet about those parameters : -P%p -F%f.hex -E -M -Y
I look microchip datasheets but i didn't find any !
Did somebody know where i could find the origin of those parameters?
Thanks for all.
DavidA
Has thanked: 58 times
Been thanked: 258 times
Re: pickit3 parameters
Post by DavidA »
-P$target-device$ -F$hex-filename$ -E -M -Y -L -V5.0 -B
* The -B (batch) is only to keep the DOS window open after programming to
see completion messages and could be left out. A space bar press will exit DOS.
* Erase all -E.
* Write all -M.
* Verify all -Y.
* If the PIC hangs after programming add a -L to release the MCLR.
* Add an V5.0 or V3.3 and possibly other voltages to power the PIC from the Pickit3 USB.
Is what i found, this may not be the case, ben might come in and tell me its wrong :)
Hi stephan,
You should find details of command line switches within the microchip folder:
....\Microchip\MPLAB IDE\Readmes
There you will see a text file called:
Readme for PK3CMD.txt
Just in case you have not got it, I have attached the text file.
Note: It is best to open file with Wordpad and not notepad.
Edit: For the latest version see:
http://www.microchip.com/stellent/idcpl ... t=SW007002
which is the website that hosts MPLAB.
Download:
MPLAB IDE Current Release Notes
Text file will be contined within zip file.
(12.59 KiB) Downloaded 373 times
stephan
Flowcode v5 User
Has thanked: 1 time
Post by stephan »
I would like to thank you ,that what i was looking for !
Stephan
Not sure if your referring to mine or Daves post (or both), but thanks anyway.
Glad you have found what your looking for.
Thanks for letting us know.
tmd_63
Flowcode V4 User
Has thanked: 9 times
Been thanked: 1 time
Post by tmd_63 »
http://www.matrixmultimedia.com/mmforum ... 678#p16524
This link also shows the command line parameters for pickit 3
