ARM
wayne millard
Has thanked: 7 times
Been thanked: 12 times
ARM
Post by wayne millard »
Hi every body,
Can i get a 1us interrupt from the arm ecio?
Thanks,
Wayne :)
Re: ARM
Hello Wayne,
At the moment Flowcode only supports multiples of the prescaler clock allowing for a max interrupt rate of 93600Hz. I know there is a way of creating timer interrupts that are more controllable by changing the value that is loaded into the overflow register.
Probably by using the following line of C code with a timer 1 interrupt.
Configure the timer interrupt as follows.
Internal Count 1:2
Count Mode - 8bit
Then add the following line of C code after the interrupt enable icon.
AT91C_BASE_TC1->TC_RC = 0x00000018;
This is not perfect but it will give you an interrupt rate of approx 1.0016us.
wayne millard
Re: ARM
Thanks Benj
I will give it a go thanks for the fast reply.
Wayne :D
wayne millard
Re: ARM
Hi BenJ,
i tried what you said but could not get to work what have i done wrong.
Checked with a oscilloscope only stays high.
Thanks,
Wayne
test.fcf_arm
(5 KiB) Downloaded 299 times
Re: ARM
Hello Wayne,
I have had a quick go here and its looking like the interrupt is triggering so fast that the main program never gets chance to run. Incrementing the timer overflow value a bit starts the program running as expected so I think this must be the problem. There must be more overhead to the interrupt routine then I originally thought. Sean is the guy who would know but he is currently away on holiday this week.
wayne millard
Re: ARM
Thanks benj,
i need to generate times from as little as 50us to 30ms to a accuracy of 1us. i tried with a pic could only get about 10us. so then got the arm development hopping that this would do it.
Wayne
Re: ARM
Hello Wayne,
Ok you could do something like this.
You know that loading the value 0x18 into the timer rollover register gives a 1us delay so you can simply multiply up this number to give you the accurate delay you require.
eg
50us would equal 50 x 0x18 = 0x4B0
30ms would equal 30 x 1000 x 0x18 = 0xAFC80
So instead of multiple timer interrupts you simply have one that runs for the entire delay.
wayne millard
Re: ARM
Hi benj,
i need to calculate the time that i require in a menu. To generate a start and stop pulse's.
in a interrupt i counted the number of interrupts to give the required time.
So how would i do the same thing?
Thanks,
Wayne
