Floating point
Floating point
Is there any way of reducing the no. of digits after the decimal point when its displayed in a Lcd in Flowcode..The displayed value being a result of a floating point calculation.
For example can we display 1.23 instead of 1.23456.
Mario.
Mario.
- JohnCrow
- Has thanked: 364 times
- Been thanked: 716 times
Re: Floating point
When you print the result of a float calculation on the LCD you print it as a string.
If you need a fixed length, you can set the lenght of the string in the variables setting.
floatstring[5] would print a sting of 5 characters (including the decimal point)
Not sure if you can set a variable lenght though, never tried that.
floatstring[lenght] where length is calculated in the flowchart.
Re: Floating point
Hi Mario,
Try this attachment.
If float=1.234567, then 1.23 should be displayed on LCD.
I'm not saying this is best or simplest method, but it's the the way I would do it.
It is very easy to expand the range (currently float has to be less than 1000). and amount of decimal places.
If you want a higher range and get stuck then let me know expected float range please.
Can you let me know if this way works for you please.
Note: Untested on hardware.
- Rounding floats.fcf
- (7.5 KiB) Downloaded 774 times
Re: Floating point
I'm not sure if Medelec's example will work on the hardware as BoostC cannot do floating point operations or comparisons without using the floating point function library.
John's ides is good but if you have a varying number of integer digits then this will not always give you 2 decimal points. There is also the potential for variable corruption as you are basically trying to write to a string that isn't long enough. EDIT - I have looked into this possibility and the function was written so it actively stops any corruption so this is confirmed as not an issue.
The way I would probably do it is to change the internals.h file located in the Flowcode FCD folder.
Find the FCI_FLOAT_TO_STRING function and add this line of code to the top of the function.
Precision = 2;
You should end up with something like this.
This way you are doing less processing rather then doing all the processing and then more processing to strip off the extra numbers.
Precision = 2;
char FCI_FLOAT_TO_STRING(float Number, char Precision, char* String, char MSZ_String)
int whole;
char str_length;
char idx;
char stringidx = 0;
float real, temp;
char old;
char temp_string[10];
Precision = 2; //manually added 05/05/11Regards Ben Rowland - MatrixTSL
Re: Floating point
No worries, caught me out a few times too
Its annoying at best
But other then Floats BoostC is a great compiler. I'll maybe have a word with the authors and see if we can do anything about the poor float support.
Re: Floating point
@Ben.
Two things.
2)
For instance I was programming 16F616 with boost C and I had about 1byte of rom free. Ouch! I thought, that is tight.
I then tried the 30 day trial version of hitec compiler with the same flowchart.
To my amazement I had only used 50% rom, I have put loads more calculations,decisions and RS232 outputs that give diagnostic information.
This optimization will enable great product like Flowcode to be even better as there will be more room available on the chip.
Two things.
1) I tried on real hardware using 18F4455, and to my surprise it did actually workBenj wrote:I'm not sure if Medelec's example will work on the hardware as BoostC cannot do floating point operations or comparisons without using the floating point function library.
2)
Talking of BoostC are they able to optimise code like Hitec compiler?Benj wrote: But other then Floats BoostC is a great compiler. I'll maybe have a word with the authors and see if we can do anything about the poor float support.
- Same Flowchart as above but configured and tested with 18F4455
- (8 KiB) Downloaded 751 times
Re: Floating point
Hi Medelec,
Wow ok that's great. I wonder why that works when the float operations require the functions. Thanks for letting me know.I tried on real hardware using 18F4455, and to my surprise it did actually work![]()
To be fair Hi Tech is probably the better compiler but it does have its issues. Mainly the price to buy a license, $1195 for a license that does not switch off the optimization and this only works for either 16F or 18F devices so essentially you have to buy it twiceTo my amazement I had only used 50% rom, I have put loads more calculations,decisions and RS232 outputs that give diagnostic information.
Re: Floating point
I was asking if the makers of Boostc could optimise code, similar to Hitec compiler.
Was not suggesting to use Hitec because of how expensive it is.
Re: Floating point
I will also suggest this to the guys at Sourceboost and see if there is anything that can be done to make the code more efficient.
Spanish_dude
- Has thanked: 63 times
- Been thanked: 102 times
Re: Floating point
Benj wrote: Mainly the price to buy a license, $1195 for a license that does not switch off the optimization and this only works for either 16F or 18F devices so essentially you have to buy it twice
I didn't know it was that expensive
Re: Floating point
Ben,
Your idea of :
Would be a better way to go.
No only does it simplify the flowchart, It would use up less room on target device.
Re Boost C V Hitec.
Boost C appears to have less bugs and is more compatible on different window versions.
E.g when I was testing Hitec compiler in demo mode ,although code length was significantly reduced,
Using same flowchart:
Hex file generated by 64bit win7 (did not work correctly,no RS232 chars on hyperterminal) was a lot different to hex file generated by 32bit win7 (100% working)
This is not the case with BoostC.
As for the cost: Ouch! I can see why you don't go down the full Hitec route. I can't imaging any Flowcodes being sold that is compatible for Both 16F and 18F devices ...hmm cost about £1500...hmm wheres my credit card
Your idea of :
Precision = 2; No only does it simplify the flowchart, It would use up less room on target device.
Re Boost C V Hitec.
Re: Floating point
Hello all,
Just had a thought and if anyone needs to have multiple precisions on the floating point string output then this should work.
Change the line in the internals file to this.
Precision = FCV_PRECISION;
and then in your Flowcode program make a byte variable named precision. Load this variable with your required number of decimal points eg 2 or 6 and then run the function as normal.
The only downside to this mod is that the internals file will not compile correctly without the precision variable present in your program.
Therefore I recommend you keep two versions of the internals file so you can switch between them if necessary.
Re: Floating point
I have had an idea base on
Is it possible to do something like:?
But in the correct format since the above is incorrect?
I don't the correct way of checking to see if a variable named Precision has been defined.
Reason I would like to do it this was is so two PIC_CAL_String.c are not required.
Also if Precision variable within Flowcode was not created, then no errors would be produced and Precision would be the default setting.
When Precision was created within flowchart and set to 2, using just :
with Flowocde V5 failed to compile with:
C:\Program Files (x86)\Flowcode\v5\FCD\..\CAL\PIC\PIC_CAL_String.c(353:14): error: unknown identifier 'FCV_PRECISION'
C:\Program Files (x86)\Flowcode\v5\FCD\..\CAL\PIC\PIC_CAL_String.c(353:14): error: invalid operand 'FCV_PRECISION'
C:\Program Files (x86)\Flowcode\v5\FCD\..\CAL\PIC\PIC_CAL_String.c(353:12): error: failed to generate expression
This is not high on my list of importance, but would be a nice thing to do.
But i'm not sure on the correct format.Benj wrote: Change the line in the internals file to this.
MX_UINT8 FCI_FLOAT_TO_STRING(MX_FLOAT Number, MX_UINT8 Precision, MX_STRING String, MX_UINT8 MSZ_String)
MX_SINT16 whole;
MX_UINT8 str_length;
MX_UINT8 idx;
MX_UINT8 stringidx = 0;
MX_FLOAT real, temp;
MX_UINT8 old;
MX_UINT8 temp_string[10];
#ifdef FCV_PRECISION;
#endifBut in the correct format since the above is incorrect?
Precision = FCV_PRECISION; C:\Program Files (x86)\Flowcode\v5\FCD\..\CAL\PIC\PIC_CAL_String.c(353:14): error: unknown identifier 'FCV_PRECISION'
- JonnyW
- Been thanked: 290 times
Re: Floating point
Hi Martin.
Change
To
For the correct syntax. But am I right that FCV_PRECISION is a variable? You can not use the pre-processor on variables - this is a text replacement only, before the variables are defined.
Either you can '#define USE_PRECISION' in supplementary code or some flag to use the FCV_VARIABLE:
#ifdef USE_PRECISION
#endif
Or use C code without preprocessor:
if (FCV_PRECISION != 0) Precision = FCV_PRECISION;
In v5 the code can be told to generate functions however you want, so this is not necessary.
Cheers,
Jonny
Change
To
#endif
Cheers,
Jonny
Re: Floating point
Thanks for your reply Jonny.
My intention is to either add a variable in Flowchart called Precision (via normal variable manager and not C if poss) and assign with the number of places to round a string to that has been converted from a float.
E.g Float_Var=1.234567
Precision=3
After FloatToString
String_Var = "1.234"
Or not have the variable in Flowchart called Precision at all so:
Float_Var=1.234567
After FloatToString
So I was going to place in PIC_CAL_String.c a little routine to assign Precision variable that would either retrieve value from Variable in Flowchart called Precision (only if it has indeed been added)
Or just leave as is, but only if no variable in Flowchart called Precision has been added
So it's the routine to place in PIC_CAL_String.c I'm after.
From what your saying there is no automatic method of getting PIC_CAL_String.c to reassign Precision variable from the variable assigned in Flowcode.
I Do understand what your saying because preprocessor is carried out before FC variables are assigned.
I did try and place:
#endif
In supplementary code but there was no rounding, so may have misread your reply.
Maybe I should of done something to PIC_CAL_String.c as well?
Tried adding:
#endif
As well as code supplementary code
No errors, but not rounding either.
Attached is flowchart Im trying the rounding on.
I appreciate your reply Jonny
Precision=3
After FloatToString
Float_Var=1.234567
After FloatToString
#endif
Tried adding:
#endif
- (11.5 KiB) Downloaded 532 times
- JonnyW
Re: Floating point
Hi Martin. Sorry, I wasn't clear, heads in the clouds today!
1) In supplementary code add the line:
2) In the CAL string stuff at the start of the FCI_FLOAT_TO_STRING() function add:
3) Create a Flowcode global variable called 'Precision' and assign it the value 3 or at the start of Main() (or in its initialiser in v5). This will be used in the CAL stuff as FCV_PRECISION.
This should work as you want it to. Note, this isn't exactly what I was trying to say before - I have changed this a little so if you do not define FLOAT_PRECISION then the code will work as it previously did, and if you define this as a constant you do not need the variable.
Cheers,
Jonny
#define FLOAT_PRECISION FCV_PRECISIONCode: Select all
#ifdef FLOAT_PRECISION
Precision = FLOAT_PRECISION;
#endifThis should work as you want it to. Note, this isn't exactly what I was trying to say before - I have changed this a little so if you do not define FLOAT_PRECISION then the code will work as it previously did, and if you define this as a constant you do not need the variable.
Cheers,
Jonny
Re: Floating point
No problem Jonny,
Thank you for replying.
I tried what you suggested but unfortunately still could not get it to work.
I looks like
Is not being accessed.
To confrim this I altered code slightly to:
Precision was not assigned to 3
Even though added
to supplementary code etc: Martin
I looks like
#endifTo confrim this I altered code slightly to:
Precision = 2;
#endif
MX_SINT16 whole;
MX_UINT8 idx;
MX_UINT8 old;
Even though added
hyperion007
- Has thanked: 49 times
- Been thanked: 101 times
Re: Floating point
Sorry to bumb this old thread but I can't seem to get any further with my questions.
The math function: fround(x,y) will not compile in FC6
I need to round off a floating number to two decimal places. I know that I can change the precision as suggested above but I need the default precision for all the calculations leading up to where I need to round the number. And if I just change the precision, will that not just discard the digits below the two decimal places?
If the number originally is say 123.45678 I need it to round to 123.46 and not 123.45
And I would like to avoid changing the precision back and forth every cycle.
Any ideas?
Any ideas?
