E-blocks PC interface
NerdHerd
Has thanked: 2 times
Post by NerdHerd »
Hi, im new to the e-blocks and was mondering if somebody could tell me how to connect the eb006 board to the PC and what must i do software wise to communicate between the flow code and labview? :?:
NerdHerd
Re: E-blocks PC interface
Post by NerdHerd »
Anything you have to help will be appreciated maybe just the flow code side of things ..and is the USB cable only used for programming or can i use it to communicate with other software?
Spanish_dude
Has thanked: 63 times
Been thanked: 102 times
Post by Spanish_dude »
To connect the PIC Multiprogrammer board to your PC you'll need a USB type A to B cable and plug it into your PC and multiprogrammer board.
Connect a DC 12V or 14V supply to GND and +14V.
I can't help you for labview.
Cheers,
Nicolas
The USB socket on the EB006 is only available for programming, ICD and the Scope operation.
To allow Labview/VB/Delphi to work using USB with the EB006 board you will need the following.
18F4455 chip or other USB compatible device
4MHz crystal or other USB compatible crystal
EB055 USB E-block
The EB055 datasheet should detail everything you need to know.
An ECIO is also a great choice for doing USB communications.
