ADC voltage
wardnica
Has thanked: 1 time
ADC voltage
Post by wardnica »
I'm trying to measure a voltage that my anemometer transmits with my 16F690, (voltage range between 0 - 5 V.)
(flowcode 4)
Re: ADC voltage
You should just be able to use the ADC component to sample and read back the voltage.
wardnica
Has thanked: 1 time
Re: ADC voltage
Post by wardnica »
this error
test.fcf
when i try to compile to the chip, i get an error.
(6.5 KiB) Downloaded 311 times
Re: ADC voltage
Your Vin variable is a Byte.
Try creating a float variable and then use this to collect the voltage. Once you have done this you should be able to convert the float to a byte correctly.
