18F67k22
Re: 18F67k22
Hello Wolfgang,
What is the problem you are having?
saschech@gmx.de
- Has thanked: 1 time
- Been thanked: 26 times
Re: 18F67k22
Hello Benj
I cant set config-bits and speed,show screen-shot`s
Regards Wolfgang
Regards Wolfgang
- (120.71 KiB) Downloaded 1586 times
- (49.38 KiB) Downloaded 1586 times
saschech@gmx.de
Re: 18F67k22
Hello Benj
If i want compile....
Regards Wolfgang
Regards Wolfgang
- (29.77 KiB) Downloaded 1582 times
Re: 18F67k22
Hi Wolfgang,
The first screenshot shows a 18F45K20, is this correct?
As for the configuration problems here is an updated set of configuration files for PPP that should allow this device to work correctly.
You will need to extract the files from the archive and then copy into your "Flowcode v4/Tools/PPP" directory.
- PPP.zip
- (1.18 MiB) Downloaded 309 times
saschech@gmx.de
Re: 18F67k22
Hello Benj
The 18F45K20 can work with 64MHZ.....
set the config bits , work with the new ppp ok,
but compile to hex,i have the same error.
Regards Wolfgang
Regards Wolfgang
- (17.3 KiB) Downloaded 1574 times
Re: 18F67k22
OK these definitions have now been fixed and will be included in the update.The 18F45K20 can work with 64MHZ.....
Great thanks for letting me know.set the config bits , work with the new ppp ok,
I will see if I can get this fixed for you also.but compile to hex,i have the same error.
Re: 18F67k22
Here is an updated FCD for the 18F45k20 device.
- 18F45K20.fcd
- (13.3 KiB) Downloaded 332 times
saschech@gmx.de
Re: 18F67k22
Hello Benj
Thank you for effort,but the file is for 18F45k20;
must i rename the file to 18f67k22 ; because i have compile rerror with this chip?
Regards Wolfgang
Regards Wolfgang
Re: 18F67k22
Hello Wolfgang,
Please try this FCD and ADC24 component C file and let me know how you get on.
I sent the other FCD because I got a PM from David saying you had requested this updated FCD.
- PIC_ADC_24.c
- (8.89 KiB) Downloaded 303 times
- 18F67K22.fcd
- (15.89 KiB) Downloaded 284 times
saschech@gmx.de
Re: 18F67k22
Hello Benj
I changing files without succsess.
Regards Wolfgang
Regards Wolfgang
- (29.88 KiB) Downloaded 1557 times
Re: 18F67k22
Hi Wolfgang,
I noticed this in your command line parameters.
_ecio40pin
This should not be there!
Please can you go into the Chip -> Compiler options menu and click restore defaults and then see if this text is still present in your output window.
If you could upload your file to the forums then I will see if I can replicate your problem here.
_ecio40pin
saschech@gmx.de
Re: 18F67k22
Hello Benj
I name my project _ecio40pinxxxxx because my print is the identical construction with the 18F67k22.
Your tip "take default`s" dos not fix the error.
So i start new with input macros....after a 2 adc i have the error ; the thame after i put in a pwm macro
Regards Wolfgang
Regards Wolfgang
- (40 KiB) Downloaded 1550 times
- (64.54 KiB) Downloaded 1550 times
- _ecio40pin18F67K22.fcf
- (124.5 KiB) Downloaded 228 times
saschech@gmx.de
Re: 18F67k22
Hello Team
What can i do fix the error`s ? ; Because I cant go on with my project!
Regards Wolfgang
Regards Wolfgang
Re: 18F67k22
Hi Wolfgang,
The ADC is compiling correctly for us here on the new version using the files I previously attached so it must be a problem with the beta release of the compiler. We are in the process of testing the 4.5 release now so hopefully we will have something to fix your problem very shortly.
