Article: https://www.flowcode.co.uk/old_site/resources/get ... php?id=382
If you have any questions for the author or comments on the article, please post them below.
MX018 - Simple Masking Technique
Re: MX018 - Simple Masking Technique
Hi David.
Thanks for the great article!
Would it be possible (if people would find it useful?) to expand this article to cover other masking, Checking and toggling bits and bytes.
E.g to set bit 3 within a variable place in a calculation box: which is same as
You can replace | with OR
To toggle a bit 3 within a Variable place in a calculation box: which is same as
You can replace ^ with XOR
To check for bit 2 within a Variable place in a decision branch:which is same as
You can replace & with AND
To Clear a register within a C code box
E.g If I want to clear bit 7 of option_reg to enable weak pull -ups
+ loads more useful bytes or bits manipulation I have seen scattered around.
Then it could be used as a reference sheet without searching the forum for each operation, all can be found in one place.
variable = Variable |(1<<3) Code: Select all
variable = Variable |8 You can replace | with OR
Variable = Variable ^(1<<3) Code: Select all
variable = Variable ^8 You can replace ^ with XOR
variable = &(1<<3)Code: Select all
variable & 8 You can replace & with AND
clear_bit(option_reg , 7);Then it could be used as a reference sheet without searching the forum for each operation, all can be found in one place.
Spanish_dude
- Has thanked: 63 times
- Been thanked: 102 times
A bit more info for those who would like to know how the clear_bit works:
The clear_bit macro can be easily made by doing :
If bit is set to (let's say) 4, the value of "1 << bit" will be 0001 0000 or 16(dec)
Using the ~ sign will invert the value so instead of having a value of 0001 0000 (or 16 dec) you'll have 1110 1111 (or 239 dec)
Next is AND'ing the value with var.
0 & 0 = 0
0 & 1 = 0
1 & 0 = 0
1 & 1 = 1
So if var = 1011 1010
The result would be
1011 1010
1110 1111 &
1010 1010
If you'd like to use this in a calculation box instead of a C code box you'll need to write:
Like Martin wrote in his first code-box you can set bits by OR'ing it with a specific value.
BR,
Nicolas L. F.
#define clear_bit(var, bit) (var & ~(1 << bit))Using the ~ sign will invert the value so instead of having a value of 0001 0000 (or 16 dec) you'll have 1110 1111 (or 239 dec)
0 & 0 = 0
0 & 1 = 0
1 & 0 = 0
1 & 1 = 1
The result would be
1011 1010
1110 1111 &
1010 1010
var = var & ~(1 << bit)BR,
Nicolas L. F.
brandonb
- Has thanked: 175 times
- Been thanked: 173 times
i noticed using 8 bit variables direct calculation masking result can be used to get 24 and 32bit numbers, but on hardware it doesnt work that way, <<8 will work on hardware great....however <<16 will not, i had to take the byte variable and send it to a buffer 16 bit uint variable and calculate off that..... <<24 had the same result but had to create a 32bit ulong variable to use with the <<24 shift,.....am i overlooking something here? really i dont understand why its possible to <<8 with a byte variable?
Hello Brandon,
I think the compiler may be doing some optimising here and assuming you do not want a 32-bit result when you actually do.
In C code you would tell the compiler to use a 32-bit memory by doing something like this.
unsigned long var32;
unsigned int var16;
var32 = (unsigned long) var16 << 16;
Note that there may be a good reason the compiler is forcing you not to do what you are trying to do. Maybe because the output assembler is bloated and inefficient.
The max file length issues in v4 with the FAT component were related to this very problem. We overcame the problem in v5 by using a structure to convert between 8, 16 and 32 bit values by accessing the correct location directly rather then using bit shifting.
unsigned int var16;
