Internal oscillator with 24FJ256GA110
Mathy
Has thanked: 30 times
Been thanked: 33 times
Post by Mathy »
Anybody had an example about how to use the internal oscillator ?
I would like to run at 32 Mhz but everything I try doesn't work.
It will be great if somedoby can give me the code to enable the internal oscillator.
Thank you very much :)
Re: Internal oscillator with 24FJ256GA110
I seem to remember it is a bit tricky to get this working on these devices. I have some working code at home for a dsPIC33 I think so I'll dig it out tonight.
Mathy
Post by Mathy »
Do you have your working code because I have some trouble with the fuse setting with or without external oscillator.
I would like to run at 32 Mhz with internal or 8 Mhz external oscillator.
Thank you for your time :)
Mathy
Mathy
Post by Mathy »
I always have a problem with internal or external oscillator.
I have on the same board a 33FJ with the same 20 Mhz crystal than the 24FJ256GA110.
With the 33FJ, no problem but with the 24FJ, the internal oscillator is used instead of the 20Mhz external crystal.
In the attached file, you can see my test program who doesn't work. I have nothing on the oscillator pin and my LED light on 5 time slower ( 20 Mhz / 4 ).
Thank you for your help
Mathy
Post by Mathy »
oupsss....
Flowcode1.fcf_pic16
(3.5 KiB) Downloaded 259 times
