Flowcode V4.5 Bugs ???
sotos
Has thanked: 10 times
Been thanked: 3 times
Post by sotos »
1) In simulation when i retrive values from a lookup table there is't update the corresponding variable .
2) In simulation if i use an interrupt using TMR2 who call a macro there is't update the corresponding variable .
In real HW everything working fine .
Has thanked: 114 times
Been thanked: 422 times
Re: FLOWCODE V4.5 BUGS ???
Post by Steve »
sotos wrote:1) In simulation when i retrive values from a lookup table there is't update the corresponding variable .
C code icons do not simulate and I guess that you are using C code for the lookup table.
sotos wrote:2) In simulation if i use an interrupt using TMR2 who call a macro there is't update the corresponding variable.
Simulation of timers in Flowcode is currently not very realistic. We hope that these will be simulated much better in V5.
