Macro behind switch component
Chris_Technik-Welt
Post by Chris_Technik-Welt »
I have open a V4 Project in V5.
All looks fine.
When I build the hex File I found in the compiler messages box
this Information:
Warning: function never returns: 'FCD_SWITCH0_ReadState'
er returns: 'FCD_SWITCH1_ReadState'
Warning: function never returns: 'FCD_SWITCH2_ReadState'
The switch dosent work when I write the code to hardware.
Spanish_dude
Has thanked: 63 times
Been thanked: 102 times
Re: Macro behind switch component
Post by Spanish_dude »
Could you upload tour Flowcode files ?
Hi Chris,
Are you using the latest version of the switch component C file.
Simply pop the file below into your "Flowcode/v5/Components" directory before starting up Flowcode.
FC5_PIC_SWITCH.c
(6.99 KiB) Downloaded 326 times
Has thanked: 114 times
Been thanked: 422 times
Post by Steve »
Also, make sure you have not customised the macro code behind the switch component.
Chris_Technik-Welt
Thanks for the File.
It is the same i have installed.
My Version is V5.1.0.0 (10.02)
@Steve
I have nothing change on our code.
I have write a short test.
Same Error.
switch_test.fcf
(11 KiB) Downloaded 320 times
JonnyW
Been thanked: 290 times
Post by JonnyW »
Hi there. The problem I think is with your debounce, which was not implemented in v4. In the Ext properties of your component there is a debounce time field, set to 100. Set this to 64 or less and your code should work OK, as debounce times above this currently cause problems. We will have a look in the code and address this in a future release.
Jonny
Chris_Technik-Welt
Hi Jonny
Many thanks for this information.
Yes you are right, this was the problem.
great and fast responce!!!
Thanks to all!!
:wink:
best regards
Christian
Here are the most recent updates to the switch and switch bank components for Flowcode v5.1.
These updated C files fix any issues with polarity or debounce and should allow debounce values up to 65535ms though this would only be needed to debounce one very bouncy switch :D
To update the components simply copy the C file into your "Flowcode/v5/Components" directory before starting Flowcode.
FC5_PIC_SWITCH.c
(7.14 KiB) Downloaded 310 times
FC5_PIC_SWITCHbank.c
(8.66 KiB) Downloaded 350 times
