Error unknown identifier 'ADCS2' & ADC_2' [SOLVED]
Following errors when compiling attached code:
Weighing Scale V3 ORG FROM POST.c(685:23): error: unknown identifier 'ADCS2'
Weighing Scale V3 ORG FROM POST.c(685:23): error: invalid operand 'ADCS2'
Weighing Scale V3 ORG FROM POST.c(685:18): error: failed to generate expression
Weighing Scale V3 ORG FROM POST.c(685:18): error: invalid operand '<<'
Weighing Scale V3 ORG FROM POST.c(685:12): error: failed to generate expression
Weighing Scale V3 ORG FROM POST.c(693:33): error: unknown identifier 'ADC_2'
Weighing Scale V3 ORG FROM POST.c(693:33): error: invalid operand 'ADC_2'
Weighing Scale V3 ORG FROM POST.c(693:39): error: failed to generate expression
Weighing Scale V3 ORG FROM POST.c(693:39): error: invalid operand '<<'
Weighing Scale V3 ORG FROM POST.c(693:30): error: failed to generate expression
Weighing Scale V3 ORG FROM POST.c(693:30): error: invalid operand '| '
Weighing Scale V3 ORG FROM POST.c(693:9): error: failed to generate expression
Although the original target device was 16F876, Still get same errors with 16F887.
However using 16F887 this is from the ADC part of the C file:
void FCD_ADC0_SampleADC()
    /*******Supported Devices******************************************************************
    // 16C72, 16C72A, 16CR72, 16F72, 16C73, 16C73A, 16C73B, 16F73, 16C74, 16C74A, 16C74B, 16F74,
    // 16C76, 16F76, 16C77, 16F77, 16F818, 16F819, 16F870, 16F871, 16F872, 16F873, 16F873A,
    // 16F874, 16F874A, 16F876, 16F876A, 16F877, 16F877A,
        #define MX_ADC_CHANNEL        ADC_2
        #define MX_ADC_SAMP_TIME     1
        #define MX_ADC_CONV_SP        40
        #define MX_ADC_VREF_OPT        3
        //set up ADC conversion
        char old_tris, cnt;
        //find appropriate bit
        #if (MX_ADC_CHANNEL == 0)
            #define MX_ADC_TRIS_MSK  0x01
            #define MX_ADC_TRIS_REG  trisa
            #if (MX_ADC_VREF_OPT == 0)
                adcon1 = 0x0E;
            #else
                adcon1 = 0x05;
            #endif
        #endif
        #if (MX_ADC_CHANNEL == 1)
            #define MX_ADC_TRIS_MSK  0x02
                adcon1 = 0x04;
            #else
                adcon1 = 0x08;
            #endif
        #endif
        #if (MX_ADC_CHANNEL == 2)
            #define MX_ADC_TRIS_MSK  0x04
                adcon1 = 0x02;
            #else
                adcon1 = 0x03;
            #endif
        #endif
        #if (MX_ADC_CHANNEL == 3)
            #define MX_ADC_TRIS_MSK  0x08
                adcon1 = 0x04;
            #else
                #pragma error "Target device is currently using AN3 for VREF+"
            #endif
        #endif
        #if (MX_ADC_CHANNEL == 4)
            #define MX_ADC_TRIS_MSK  0x20
                adcon1 = 0x02;
            #else
                adcon1 = 0x03;
            #endif
        #endif
        #if (MX_ADC_CHANNEL == 5)
            #define MX_ADC_TRIS_REG  trise
                adcon1 = 0x09;
            #else
                adcon1 = 0x01;
            #endif
        #endif
        #if (MX_ADC_CHANNEL == 6)
                adcon1 = 0x00;
            #else
                adcon1 = 0x01;
            #endif
        #endif
        #if (MX_ADC_CHANNEL == 7)
                adcon1 = 0x00;
            #else
                adcon1 = 0x01;
            #endif
        #endif
        //sanity check
        #ifndef MX_ADC_TRIS_REG
            #pragma error "ADC Type 1 conversion code error - please contact technical support"
        #endif
        //assign conversion speed
        #if (MX_ADC_CONV_SP > 3)
            st_bit(adcon1, ADCS2);
        #endif
        //store old tris value, and set the i/o pin as an input
        old_tris = MX_ADC_TRIS_REG;
        MX_ADC_TRIS_REG = MX_ADC_TRIS_REG | MX_ADC_TRIS_MSK;
        //turn ADC on
        adcon0 = (0x01 | (MX_ADC_CONV_SP << 6)) | (MX_ADC_CHANNEL << 3);
        //wait the acquisition time
        cnt = 0;
        while (cnt < MX_ADC_SAMP_TIME) cnt++;
        //begin conversion and wait until it has finished
        adcon0 = adcon0 | 0x04;
        while (adcon0 & 0x04);
        //restore old tris value, and reset adc registers
        MX_ADC_TRIS_REG = old_tris;
        adcon1 = 0x07;
        adcon0 = 0x00;
        #undef MX_ADC_CHANNEL
        #undef MX_ADC_TRIS_REG
        #undef MX_ADC_TRIS_MSK
        #undef MX_ADC_SAMP_TIME
        #undef MX_ADC_CONV_SP
        #undef MX_ADC_VREF_OPT
MX_UINT8 FCD_ADC0_ReadAsByte()
        MX_UINT8 retVal;
        //Configure & Enable ADC Channel
        FC_CAL_Enable_ADC ( ADC_2_MX_ADC_CHANNEL , ADC_2_MX_ADC_CONVSP , ADC_2_MX_ADC_VREFOP , ADC_2_MX_ADC_ACTIME );
        retVal = FC_CAL_Sample_ADC( 0 );                //Perform Sample - Return as byte
        FC_CAL_Disable_ADC ();
        return (retVal);
MX_UINT16 FCD_ADC0_ReadAsInt()
        MX_UINT16 retVal;
        retVal = FC_CAL_Sample_ADC( 1 );                //Perform Sample - Return as MX_UINT16
        return (retVal);
MX_FLOAT FCD_ADC0_ReadAsVoltage()
        MX_UINT16 iSample;
        MX_FLOAT fSample, fVoltage, fVperDiv;
      #ifdef MX_ADC_BITS_8
        iSample = FC_CAL_Sample_ADC( 0 );                                //Perform Sample - Return as byte
      #else
        iSample = FC_CAL_Sample_ADC( 1 );                                //Perform Sample - Return as MX_UINT16
      #endif
          FC_CAL_Disable_ADC ();                                            //Switch off ADC peripheral
        fVoltage = float32_from_int32( ADC_2_MX_ADC_VREFVOL );                //Convert reference voltage count to floating point (0 - 500 x 10mV)
        fVoltage = float32_mul(fVoltage, 0.01);                            //Convert reference voltage count to actual voltage (0 - 5)
        fVperDiv = float32_mul(fVoltage, 0.00390625);                    //Convert actual voltage to voltage per division (VRef / 256)
      #endif
      #ifdef MX_ADC_BITS_10
        fVperDiv = float32_mul(fVoltage, 0.000976);                        //Convert actual voltage to voltage per division (VRef / 1024)
      #endif
      #ifdef MX_ADC_BITS_12
        fVperDiv = float32_mul(fVoltage, 0.00024414);                    //Convert actual voltage to voltage per division (VRef / 4096)
      #endif
        fSample = float32_from_int32(iSample);                            //Convert to floating point variable
        fVoltage = float32_mul(fSample, fVperDiv);                        //Calculate floating point voltage
        return (fVoltage);
void FCD_ADC0_ReadAsString(MX_CHAR* FCR_RETVAL, MX_UINT8 FCR_RETVAL_SIZE)
        MX_FLOAT fVoltage;
        fVoltage = FCD_ADC0_ReadAsVoltage();
        FCI_FLOAT_TO_STRING(fVoltage, 2, FCR_RETVAL, FCR_RETVAL_SIZE);    //Convert to String
void FCD_ADC0_ADC_RAW_Configure_Channel()
MX_UINT8 FCD_ADC0_ADC_RAW_Sample_Channel_Byte()
        return FC_CAL_Sample_ADC( 0 );                                    //Perform Sample - Return as byte
MX_UINT16 FCD_ADC0_ADC_RAW_Sample_Channel_Int()
        return FC_CAL_Sample_ADC( 1 );                                    //Perform Sample - Return as MX_UINT16
MX_UINT8 FCD_ADC0_ADC_RAW_Average_Channel_Byte(MX_UINT8 NumSamples, MX_UINT8 DelayUs)
        MX_UINT32 average = 0;
        MX_UINT8 count;
        for (count=0; count<NumSamples; count++)
            average = average + FC_CAL_Sample_ADC( 0 );                    //Perform Sample - Return as byte - add to average
            if (DelayUs)
                delay_us(DelayUs);                                        //If delay is not 0 then pause between samples
        average = average / count;
        return (average & 0xFF);                                        //Return average as byte
MX_UINT16 FCD_ADC0_ADC_RAW_Average_Channel_Int(MX_UINT8 NumSamples, MX_UINT8 DelayUs)
        MX_UINT8 count;
            average = average + FC_CAL_Sample_ADC( 1 );                    //Perform Sample - Return as MX_UINT16 - add to average
            if (DelayUs)
        return (average & 0x1FFF);                                        //Return average as MX_SINT16
void FCD_ADC0_ADC_RAW_Disable_Channel()
        FC_CAL_Disable_ADC ();                                            //Disable ADC Channel
The relevant part being:
Looks like ADC0_SampleADC() is cause issue?
Since Type 1 devices is being pickup (16F887 is type7 ) and ADC_2 is in place of a number.
I have suggest to delete ADC and re-add component which fixes the issue.
See:
http://www.matrixmultimedia.com/mmforum ... =7&t=10360
Original file can be found here:
http://www.matrixmultimedia.com/mmforum ... 162#p32695
(23.7 KiB) Downloaded 288 times
Weighing Scale V3 ORG FROM POST.fcf
(26.24 KiB) Downloaded 328 times
JonnyW
Has thanked: 63 times
Been thanked: 290 times
Re: Error unknown identifier 'ADCS2' & ADC_2'
Post by JonnyW »
Hi. The issue is probably due to a port of a v4 program.
(2.66 KiB) Downloaded 1905 times
The code has been customized and retains the v4 code, which is no longer valid in v5. I think this could also be fixed by going into the component and un-customizing it.
Jonny
Ah yes you are correct Jonny, well spotted!
As I did not customise the component, I did not even think to look at that part.
Odd that it complies with V4 OK.
Thanks for your reply.
