Dear experts,
Are there any macro available for data (variable) read/write to the PIC-EEPROM?
For a answer thank you very much in advance.
Best regards
Rabbit
variable read/write to the PIC-EEPROM
Re: variable read/write to the PIC-EEPROM
Hi Rabbit,
Yes there is a EEPROM component in the Misc section of the Component toolbar which you should be able to use if your device supports EEPROM memory.
Many thanks for your answer. I know this EEPROM component in the Misc section. My question was inexactly. I'm looking for an example or an instruction for using this component.
Have a nice weekend
Rabbit
Have a nice weekend
Rabbit
replaced last post as i reworked the flowchart to add write, try this all it does is writes numbers to eeprom then reads em back , not an elegant solution but very quick and easy to do hth
- eeprom write read1.fcf
- (24.25 KiB) Downloaded 423 times
