Can not compile
- Flowcode V4 User
- Has thanked: 2 times
Can not compile
Return code = -1073741819
Flowcode was unable to assemble the ASM file due to the following errors:
FINISHED
I just recompile the project and that is what I got, I did not even change anything and following errors: does not help!
FINISHED
- DavidA
- Has thanked: 58 times
- Been thanked: 258 times
Re: Can not compile
have you tried reinstalling Flowcode? You should not need to enter any licence information in (this is stored in windows registry even after uninstall), so you can just defer the entering of any cd keys.
The latest patch of Flowcode for your version can be downloaded by entering the last 12 characters of your licence key into the Flowcode Downloads section on the Flowcode main page: http://www.matrixmultimedia.com/flowcode.php
Also if you are using your .hex file in a schematic design in Proteus, this may cause an issue, this can be solved by closing Proteus.
- Flowcode V4 User
Re: Can not compile
I reinstalled it and it got bit more interesting:
Flowcode1.c
Starting preprocessor: c:\PROGRA~1\MATRIX~1\FLOWCO~2\boostc\pp.exe Flowcode1.c -i c:\PROGRA~1\MATRIX~1\FLOWCO~2\boostc\include -d _PIC16F1823 -la -c2 -o Flowcode1.pp -v -d _BOOSTC -d _PIC16 -d _PIC16x -d _CHAR_INDEX
Flowcode1.c(53:2): error: unknown identifier 'ansela'
Flowcode1.c(53:2): error: invalid operand 'ansela'
Flowcode1.c(53:9): error: failed to generate expression
Flowcode1.c(54:1): error: unknown identifier 'anselc'
Flowcode1.c(54:1): error: invalid operand 'anselc'
Flowcode1.c(54:8): error: failed to generate expression
Flowcode1.c(58:2): error: unknown identifier 'option_reg'
Flowcode1.c(58:2): error: invalid operand 'option_reg'
Flowcode1.c(58:13): error: failed to generate expression
Flowcode1.c success
failure
Return code = 1
Flowcode was unable to compile the flowchart's C code due to the following errors:
If your flowchart contains C code, please review this carefully. If your flowchart contains no C-code or you have thoroughly reviewed the code, contact Technical Support.
FINISHED
I don't use proteus at all.
I would be so happy if you had linux version, this software is the only reason why I keep windows.
Flowcode1.c
Flowcode1.c success
failure
Return code = 1
FINISHED
Re: Can not compile
Hi try a forum search on ansela there are a few posts dont know how old your V4 is but a post by medelec here http://www.matrixmultimedia.com/mmforum ... %27#p22802 points towards using a different compiler as early boostc dint support the chip you are using, does compiling to say a pic 628a give the same result, hth
- Flowcode V4 User
Re: Can not compile
Flowcode1.c
Starting preprocessor: c:\PROGRA~1\MATRIX~1\FLOWCO~2\boostc\pp.exe Flowcode1.c -i c:\PROGRA~1\MATRIX~1\FLOWCO~2\boostc\include -d _PIC16F84 -la -c2 -o Flowcode1.pp -v -d _BOOSTC -d _PIC16 -d _CHAR_INDEX
Flowcode1.c success
success
Return code = 0
c:\program files\matrix multimedia\flowcode v4\boostc\boostlink_pic.exe -ld "C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\lib" libc.pic16.lib flowcode.pic16.lib rand.pic16.lib float.pic16.lib "Flowcode1.obj" -t PIC16F84 -d "C:\Documents and Settings\Administrator\My Documents\Flowcode\test" -p "Flowcode1"
FINISHED
Flowcode1.c success
success
Return code = 0
FINISHED
- DavidA
Re: Can not compile
Hello are you using Flowcode v4.5? You can check this in the Help >> About section of Flowcode.
- Flowcode V4 User
Re: Can not compile
Should be the latest, I think.
Flowcode
Professional Version
Flowcode v4.5.18.74
Flowcode
Flowcode v4.5.18.74
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: Can not compile
There are a few posts in this forum with this error code:
http://www.matrixmultimedia.com/mmforum ... 1073741819
There's also a post on the FAQ site:
http://www.matrixmultimedia.com/support ... 1819#p1147
- Flowcode V4 User
Re: Can not compile
It did not help entirely but put me on right tracks, thanks.
all the updates and MS fixes I already had so I could not do much there, instead I limited number of processors/ cores my windows run on and that seems to fix it which actually make sense now it happened after I updated Virtualbox.
I wish flowcode was Linux application
- Flowcode V4 User
Re: Can not compile
Spoke too soon When I add While loop (unmodified empty while loop) it comes up with:
Internal Error: Unable to resolve label ID:268444239 - 0x1000224F
failure
Return code = -2
FINISHED
failure
Return code = -2
FINISHED
