Scheme size is zero or negative!!!!
saakis
Has thanked: 8 times
Been thanked: 3 times
Post by saakis »
I got these message when I tried to download the firmware to a 18F4455 chip. Trying to send fuse data is ok, to view the Pic Micro is ok from the PPP program. Programming a 18F4450 by put it on a HP 488 board is ok,but trying to do the same with a 18F4455 smd connected with cables to the board is not possible to program the chip, since the recognition is not possible and the message "scheme size is zero or negative"is coming up. I designed to different boards but same result! Any idea of what is going wrong?
Thank you
DavidA
Has thanked: 58 times
Been thanked: 258 times
Re: Scheme size is zero or negative!!!!
Post by DavidA »
What version of PPP are you trying to program the device with? Help >> About in PPP.
saakis
Post by saakis »
It is version 3.11.15.30.
DavidA
Post by DavidA »
I see you are a Flowcode v5 user, please try the same thing from the PPP bundled with v5, it is a later version (3.13) and can be found in the Tools folder of the Flowcode installation.
saakis
Post by saakis »
Hello David, yes indeed there is the v3.13 in the tools of v5 but is only executable and I can't install it. Any way when I try to run it I have the message " Registry error:Failed to get data for 'CONFIG 8L' "and when I press OK and run the program PPP I got the same situation as I mention, Scheme size is zero or negative.
Is something wrong with installation?
saakis
Post by saakis »
Hello again! I programmed the same board, I could't do with the HP 488 and PPP, with a friend programmer using the Microchip software. The erase and download worked perfect and we did it in two different boards I made. Now I try to reload the hex with HP 488 again and it is not possible. What is going wrong?
Sakis
DavidA
Post by DavidA »
saakis wrote:Hello David, yes indeed there is the v3.13 in the tools of v5 but is only executable and I can't install it. Any way when I try to run it I have the message " Registry error:Failed to get data for 'CONFIG 8L' "and when I press OK and run the program PPP I got the same situation as I mention, Scheme size is zero or negative.
Hello Please try the v5 PPP again, but to fix the Registry error 'CONFIG 8L' issue please try this fix in this thread:
http://www.matrixmultimedia.com/mmforum ... +81#p32373
You could also try changing the VDD switching option in the PPP options window to see if this helps at all.
To do this tick the manual override tickbox and then try each of the three settings in turn to see if this fixes the problem you are having.
saakis
Post by saakis »
I tried all possible combinations. I also replace the power supply increase it to 14.5 V. Nothing. I don't understand why with 18f4450 is fine, what is the difference between them. I'm almost desperate , I'm thinking to by a programmer...
Sakis
