DS1820
jgu1
Has thanked: 1135 times
Been thanked: 299 times
DS1820
Post by jgu1 »
Hi all!
I've been playing this project and it works fine, with very accurate display of the temperature. But when I measure a temperature below zero degrees I get this view: Examble: -5.-18 C and I want it to view -5.18 C
I've tried almost everything but can not get minus line after the comma away. I can see in the calculation it must have something to do with mod. Is there anyone who can help. :D
Best regard
Jorgen
1. Single OneWire_DS18B20_ 16f886.fcf
(11.97 KiB) Downloaded 325 times
Re: DS1820
Hello Jorgen,
What happens if you make Temp2 a Unsigned Int in the variable manager? Does this help at all?
jgu1
Re: DS1820
Post by jgu1 »
Hi Ben!
Thank´s It work :D . But the decimals after the decimal point shifts between 1 and 2 decimal places. Do you have a proposal for how I either keep it in one or two decimal.
Best regard
Jorgen
Re: DS1820
Hello Jorgen,
You might be able to do something like this.
LCD Print Number Temp2
Decision Temp2 < 10
Yes: LCD Print Number 0
jgu1
Re: DS1820
Post by jgu1 »
Hi Ben!
You're a genius. :D It does certainly seem to work in simulation. Now you will probably wonder how I can simulate oneWire component, but I have put a pot (analog) into my FC and let it vary "Temp". I´ll test it in real life tonight, you will hear. But so far thanks.
Jorgen.
jgu1
Re: DS1820
Post by jgu1 »
Hi Ben!
It work´s with + C. 2digit, but when I get under 0 C I get 3 digit after the comma. It´s ok, but if you have an easy way to remove the third digit It would be nice.
Thank´s in advance
Jorgen
