Help with C component
For C and ASSEMBLY users to post questions and code snippets for programming in C and ASSEMBLY. And for any other C or ASM course related questions.
Mak24
Post by Mak24 »
We are trying to programm with C component and we are having some trouble doing it.Is there any pdf or any guide how to do it?
Re: Help with C component
Are you using the custom component in Flowcode? If so then there is a guide but it was for v3 of Flowcode so may be a bit outdated now.
http://www.matrixmultimedia.com/softwar ... owcode.pdf
http://matrixmultimedia.com/mmforums/vi ... &sk=t&sd=a
If you are not using Flowcode then what compiler are you using and what are you trying to do?
Mak24
Post by Mak24 »
Yes we are using the custom component in Flowcode,the V3 of Flowcode.Is there any way so i can call the libraries i want to use.i use <stdio.h> , <iostream.h> .Whenever i try to use my programm i get following results as error.
C:\Program Files (x86)\Matrix Multimedia\Flowcode V3\BoostC\include\stdio.h(17): error: missing semicolon
Although we tried to use semicolon in every line.
JonnyW
Has thanked: 63 times
Been thanked: 290 times
Post by JonnyW »
Can you post an example of how you are including this please? I don't have v3 to hand but line 17 in v4 is the first line of C - this means the error is probably in the line of code immediately before the #include <stdio.h> call.
Note you should not be adding a semi-colon to the end of preprocessor lines, like #include.
Cheers,
Jonny
