Analogue Infrared Reflectance Sensors
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Post by JohnCrow »
While browsing the component websites, I have recently found it hard to resist ordering various strange and unusual sensors, (especially if they are not expensive) to experiment with.
There are some interesting devices on the market today.
These cost £1.99 in the UK
A recent purchase is the Pololu QTR-1A reflectance sensor. This is already mounted on a BOB so it simplifies the way it can be used.
The package contains a small pcb (8mm x 13mm) with the sensor itself, 3x smd components.
Also included is a 3pin SIL header which has to be soldered to the sensor board to allow the signals to be connected.
(It can also be bought as a strip of 8 sensors, which can be broken down to a strips of 6 sensors and 2 sensors respectively.
The data sheet can be downloaded from here
http://www.pololu.com/docs/pdf/0J13/QTR ... n_note.pdf
Reading L-R with the connections at the top
1 = Gnd
2 = 5V
3 = Signal Out.
Signal out is connected to ADC5 on the PIC
The device can be used to sense the difference between a white and a black surface held close to the sensor.
White Surface:
This has a strong reflectance. The output will tend towards 0V
Or 0 if reading as byte or integer
Black Surface:
This has a weak reflectance. The output will tend towards 5V
Or 255 / 1023 if reading as byte or integer.
Equipment:
EB006 Programmer with 16F877A
Port E = EB017 Patch Board
Port B = EB005 LCD Display
Jumper wires to suite patch board
Software:
This simple program is just to show the operation of the device.
It would be very easy to use this as the basis of a white line follower.
The difference between the two levels is very large so would be easy to detect.
I simply setup the LCD as normal.
Then the program drops into an endless loop.
Read the ADC input on ADC5
If less than or equal to a certain value , then colour = White
If greater than or equal to a certain value then colour = Black
If between these values then colour = Gray.
I did wonder if it would give different values for different colours and thus be used as a colour detector, however this does not seem to be the case with this sensor.
But, the device works exactly as it says in the data sheet and gives a strong indication with black or white.
(17.43 KiB) Downloaded 1810 times
JohnCrow
Re: Analogue Infrared Reflectance Sensors
Post by JohnCrow »
This is the flowcode file
ADC Sensor V2-byte.fcf
(13.41 KiB) Downloaded 310 times
Enamul
Has thanked: 271 times
Been thanked: 814 times
Post by Enamul »
Nice work John. :)
I'll order one today.
Enamul
Enamul
University of Nottingham
enamul4mm@gmail.com
one application is a line follower for a robot?
Nice one John.
