I've installed C for ARM on win7 64 bit. I get the "serial number not found or incorrect" when I try to run the course. I found the registry fix on the support page and tried it but it made no difference. Also, during the installation, I got" dpinst.exe does not run ....". Tried to download the latest drivers but again, it had no effect.
C for ARM not running
- DavidA
- Has thanked: 58 times
- Been thanked: 258 times
Re: C for ARM not running
Hello mark,
To get C4ARM working on 64 bit machines you will need to follow the procedures in these two FAQs
http://www.matrixmultimedia.com/support ... f=11&t=587 - 64-bit PC serial number not found or incorrect
http://www.matrixmultimedia.com/support ... f=11&t=790 - Getting C4ARMs working on 64bit machines
The registry fix should work and give you access to the course, a common mistake is not running the file that is downloaded as an administrator by right clicking and selecting "Run as Administrator".
The dpinst.exe error is because the installer is trying to install 32bit drivers. This is covered in part by the second FAQ topic as the bootloader in the Eblock needs updating.
Hi dazz,
i'm currently working on it. maybe it will take some time because i have classes and i can only do it during nighttime. if i finished the flowchart, i'm gonna post it right away. thanks again..
