I didn't want to hijack the topic "Frequency counter 35 Mhz" so I thought it best to open a new thread.
I am working on an application where I need to determine the frequency of a digital signal appearing on the pin of a sensor IC. The PIC I'm currently using is a PIC16F1829, but I could change it to another PIC if there is one that would be better for the frequency counter or add an external clock source forTimer1, if Timer1 would be a better choice than Timer0.
The frequency counter range I need would be around 1KHz up to 1 MHz. I have reviewed the "Digital frequency counter' program which is in the FLowcode v5 Examples - Interrupts file and I like the elegance of the program, but the range is only up to 32KHz or possibly as high as 64KHz by modifying the LCD Print Number Function .
So, I was wondering if it was possible to to modify the example Digital frequency counter program to allow it to have a range up to 1 MHz and if so, how would I go about doing that? I'd certainly be willing to use another PIC if necessary.
I like medelec35's program posted under the "Frequency counter 35 Mhz" thread, and would like to know if the Digital frequency counter program can be modified to get the same result.
Frequency Counter to 1MHz
- Has thanked: 6 times
- Been thanked: 4 times
Jump to
- Announcements
- ↳ Announcements
- The Knowledge Exchange
- ↳ Programming Tips & Tricks
- ↳ Freelance Embedded Engineers
- ↳ Article Discussion
- Microcontroller Programming
- ↳ General Programming
- ↳ Flowcode V9
- ↳ Flowcode V8
- ↳ Feature Requests
- ↳ Bug Reports
- ↳ User Components
- ↳ Flowcode V7
- ↳ User Components
- ↳ Feature requests
- ↳ Bug reports
- ↳ Fixed bugs
- ↳ 8-Bit PIC
- ↳ 16-Bit PIC
- ↳ 32-Bit PIC
- ↳ AVR & Arduino
- ↳ 32-Bit ARM
- ↳ Poll Discussion
- ↳ Flowcode V6
- ↳ Flowcode v6 Beta
- ↳ Bug reports
- ↳ Getting Started
- ↳ User Components
- ↳ Bug reports
- ↳ Flowcode V5
- ↳ Flowcode V5 Issues
- ↳ Flowcode V5 Suggestions
- ↳ Flowcode V5 Free Edition
- ↳ Flowcode V4
- ↳ Flowcode 4 Bugs
- ↳ Flowcode 4 Suggestions
- ↳ Flowcode V2 & V3
- ↳ General / Misc
- ↳ Components (Comms)
- ↳ Components (Other)
- ↳ Bugs / Application Errors
- ↳ Suggestions
- ↳ BTEC Unit 6
- ↳ C and ASM Programming
- ↳ E-blocks
- ↳ Formula AllCode
- ↳ Formula Flowcode
- ↳ MIAC
- Language Support Forums
- ↳ Deutsch Support-Forum
- ↳ Forums d'aide en français
- ↳ Foro de soporte español
- Other Matrix products
- ↳ Electronics products
- ↳ Matrix Online Courses
- ↳ Other products
- ↳ CoCo
- Hidden
