Hi all, have an eb006 board. I switched my computer off, turned it on again to do some work and the usb connection has failed. In the device manager it says "unknown device" will not recognise the eb006.
Can anyone help?
Dave
USB connection failed
- Enamul
- Has thanked: 271 times
- Been thanked: 814 times
Re: USB connection failed
You can simply unplug usb cable and re-plug it..and also re-install the usb driver for EB006.
Might also be worth a power cycle:You can simply unplug usb cable and re-plug it..and also re-install the usb driver for EB006.
Pull out the PSU and USB cable, re-insert the USB and then the PSU.
