error in sim macro call2
greentech
Flowcode V4 User
Has thanked: 10 times
Been thanked: 2 times
Post by greentech »
While playing around gsm componenet i get this error. it neither works in simulation nor on real hardware.
Why?
Enamul
Has thanked: 271 times
Been thanked: 814 times
Re: error in sim macro call2
Post by Enamul »
GSM component works fine in hardware..but simulation will not work. If you think you are facing problem in hardware..you can post program so that we can have a look.
Enamul
University of Nottingham
enamul4mm@gmail.com
greentech
Flowcode V4 User
Post by greentech »
Be a life long or short, its completeness depends on what it was lived for.
I mean it should have worked in simulation as-well. New comps should be "GUI friendly"
im trying this on sim900d hardware.
GSM.fcf
(10 KiB) Downloaded 338 times
greentech
Flowcode V4 User
Post by greentech »
is there anyone in town to answer back?
Enamul
Post by Enamul »
Sorry for the delay in getting back. It seems you are FCv4 user..But the file doesn't open in FCv4.
Enamul
enamul4mm@gmail.com
Enamul
Post by Enamul »
Modem should be connected to USART. In hardware USART mode, RC6 and 7 are Tx and Rx so you can't use RTS, CTS in those pin. You can use any other pin for CTS & RTS. Some other problem in the code which I have corrected, you can go for a try. Please let us know how you are getting.
GSM.fcf
(12 KiB) Downloaded 304 times
Enamul
enamul4mm@gmail.com
greentech
Flowcode V4 User
Post by greentech »
Thank you Enamul ill give it a try tomorrow and get back to u.
JonnyW
Has thanked: 63 times
Been thanked: 290 times
Post by JonnyW »
Evening.
I agree - one of the things we hope to address in future versions is improved simulation of components. However for now the components are more focused on working on download so there will be components that do not simulate.
I will take a look at your program and see if we can remove the error message in a future update.
Cheers,
Jonny
