I2C component
sotos
Has thanked: 10 times
Been thanked: 3 times
I2C component
Post by sotos »
I would like to know if there is any restriction in numbers of I2C components that I can use in FC 5.4
when I try to use more than 4 I2C component , the compile fails and I receive many error messages . :( :( :(
In previus version of FC ( 4.5 ) I have use 5 I2C component successfuly .
S MAKRIS
Jordy101091
Has thanked: 25 times
Been thanked: 188 times
Re: I2C component
Post by Jordy101091 »
Hi Sotos,
I think you mist understand the component function idea.
If you want to use multiple I2C slave devices you only need one I2C Component.
The key to use multiple I2C slave Devices is to use there internal address to communicate with them.
Hope this help a bit.
Regards Jordy
sotos
Re: I2C component
Post by sotos »
Hi JORDY
You're right, it was my mistake to try to use multiply I2C Master componrnts . :oops: :oops: :oops:
Thanks for your answer .
Regards SOTOS
