Flowcode v5.5 with DSP for all variants
Re: Flowcode v5.5 with DSP for all variants
Hi STibor
Try running the installer again and select the repair option, it may or may not help
Dazz
Dazz
- STibor
- Has thanked: 116 times
- Been thanked: 113 times
Hi Dazz and everybody!
The repair installation does not resolve the problem.
I installed Flowcode in your other computer is completely clean installation.
Same error.
C: \ Program Files \ Flowcode \ v5 \ Components folder in the file FC5_Comps_Add.reg I do not see the DSP component.
Maybe that's the problem?
Same error.
- JonnyW
- Has thanked: 63 times
- Been thanked: 290 times
The FC5_Comps_Add.reg file is only used to repair - it is not used for install. If the components are present to add there is no reason for them not to be available to load.
I have not had this problem but will try this on a clean machine with only ARM installed and see if I can replicate it.
The file association issue is fixed - the online install for ARM has been updated so anyone downloading the install now will not have this problem (it will also install over your current v5.5 if you want).
There may be something strange with the ARM where other registry settings are required - if so I hope this is just a matter of posting a .reg file to fix.
Cheers,
Jonny
Cheers,
Jonny
- JonnyW
PS: Is the issue just with existing files from other versions - or are there issues loading AVR files into AVR and ARM into ARM?
Cheers,
Jonny
Cheers,
Jonny
- Has thanked: 7 times
- Been thanked: 12 times
Hi Jonny,
I have installed flowcode 5.5 on win7 and have problems the same as on forum about importing examples. if i install on xp laptop and try to import examples flowcode closes after import.
Wayne
Wayne
- STibor
Unfortunately, I only have a license Flowcode5 Pic Proffessional.JonnyW wrote:Hello.
Cheers,
Jonny
I downloaded the demo version Flowcode5.4 dsPIC, but it is not updated to version 5.5.
If you give me professional license (AVR DSPIC) I am very happy to do anything they test.
- JonnyW
Hello all.
I have finally admitted defeat - I have amended all the executables to version 5.5.2.1. All future downloads will have this modified version which will import DSP components from other versions correctly.
Note the import issue only affects those without the source platform installed.
For those that have upgraded to v5.5.0.0 already, the current version (v5.5.2.1) is available here:
PIC
AVR
ARM
dsPIC
You do NOT need to re-enter license information if you are upgrading.
Apologies for any inconvenience - we hope this fixes the import issues so you can all use the DSP examples!
Jonny
PIC
AVR
ARM
dsPIC
Jonny
- Has thanked: 3 times
- Been thanked: 2 times
Dear Jonny!
I try update Fv5.4PIC to Fv5.5 this installer.
The installer generate some (9) error like this:
Error 1904. Module C:\Program Files(x86)\Flowcode\v5\Components\FC5_PICI2C_Master.ocx
failed to register. HRESULT -214724770. Contact your support personnel.
PIC_Speech, PIC_SPI_Legacy, PIC_PWM etc. Try reinstall, same error...
( I have PIC and AVR licence. Use in one machine (opsys:Win7 64) )
Can you uninstall V5.5, then install V5.5
Dazz
Dazz
- JonnyW
Hello. Is this the same error for both installers (PIC and AVR)? Could there be privilege issues - can you run as administrator (the installer should automatically though)?
Jonny
Jonny
- Mantas
- Has thanked: 57 times
- Been thanked: 27 times
Hi Jonny,
One more thing, you forgot to fix the sqrt() function in the ARM version, cause I still get an error while compiling...undefined reference to float32_sqrt
Cheers,
Mantas
Cheers,
Mantas
Science is my true religion.
I was afraid to mess up other programs.
So I have not updated the AVR program,
but the problem is solved when I run the program in administrator-level ...
Happy to see DSP support! I've always wanted to build a true sine wave 12V or 24V DC to 120V AC power inverter. Do you guys think it's possible with FC v5.5 for PIC with DSP support. Cheers.
Hmm not too sure on this one. dsPIC & PIC24 may be a better option as you have more processing power and typically they also run faster then their 8-bit equivalent. Certainly worth a goDo you guys think it's possible with FC v5.5 for PIC with DSP support.
HI,
I try to use the FFT componant on a DSPIC 30F3014, with flowcode V5.5.2.1 for Pic 24 and DsPIC
I use the program
10. Frequency Analysis using FFT.fcf_pic16
It doesn't seem to work...
I have tried to find the problem with my file by adding more and more
components of 10. Frequency Analysis using FFT.fcf_pic16
and in fact it's the ReadSingleBank_FFT that produce the following problem:
G:\yann\OT\datasheet_matrix_et_autre\DS_pic\test DSP>pic30-gcc -c -mcpu=30F3014 -funsigned-char -fno-short-double -Os -I"C:\PROGRA~2\FLOWCO~1\v5\Tools\MX_bats\..\C_tools\support\h" -I"C:\PROGRA~2\FLOWCO~1\v5\Tools\MX_bats\..\MX_support" -Wall -std=gnu99 "test13e".c -o "test13e".o
test13e.c: In function 'FCD_ADC0_ReadAsString':
test13e.c
warning: pointer targets in passing argument 3 of 'FCI_FLOAT_TO_STRING' differ in signedness
test13e.c: In function 'FCD_DSP_Abs0_ReadPeak':
test13e.c
error: 'DSP_Abs_13_LEVEL_PEAK_RECORD' undeclared (first use in this function)
test13e.c
error: (Each undeclared identifier is reported only once
test13e.c
error: for each function it appears in.)
test13e.c
error: 'Peak_Idx' undeclared (first use in this function)
test13e.c
error: 'DSP_Abs_13_LEVEL_RECORD' undeclared (first use in this function)
test13e.c: In function 'FCD_DSP_Abs0_ReadTrough':
test13e.c
error: 'DSP_Abs_13_LEVEL_TRGH_RECORD' undeclared (first use in this function)
test13e.c
error: 'Trgh_Idx' undeclared (first use in this function)
test13e.c: In function 'FCD_DSP_Abs0_ReadAverage':
test13e.c
error: 'DSP_Abs_13_SAMPLE_SIZE' undeclared (first use in this function)
test13e.c
error: 'DSP_Abs_13_LEVEL_AVRG_RECORD' undeclared (first use in this function)
test13e.c
error: 'Avrg_Idx' undeclared (first use in this function)
test13e.c: In function 'FCD_DSP_Abs0_ReadPeak_Tick':
test13e.c
test13e.c
test13e.c: In function 'FCD_DSP_Abs0_ReadTrough_Tick':
test13e.c
test13e.c
test13e.c: In function 'FCD_DSP_Abs0_ReadAverage_Tick':
test13e.c
test13e.c
test13e.c: In function 'FCD_DSP_Abs0_ReadSingleBank_FFT':
test13e.c
warning: comparison is always true due to limited range of data type
test13e.c: In function 'FCM_timer_tick':
test13e.c
warning: pointer targets in passing argument 1 of 'FCD_DSP_Input0_Add_To_Buffer' differ in signedness
test13e.c: In function 'main':
test13e.c
warning: pointer targets in passing argument 1 of 'FCD_LCDDisplay0_PrintString' differ in signedness
test13e.c
3: warning: #warning "This interrupt has previously been enabled, so the macro <timer_tick> may never get called."
Error returned from [pic30-gcc.exe]
if someone hnows the problem?
Yann
I use the program
test13e.c
test13e.c
test13e.c
test13e.c
test13e.c
test13e.c
test13e.c
test13e.c
test13e.c
test13e.c
test13e.c
test13e.c
test13e.c
test13e.c
test13e.c
test13e.c
test13e.c
test13e.c
test13e.c
test13e.c
test13e.c
Yann
- test13e.fcf_pic16
- my file with problem
- (19.19 KiB) Downloaded 606 times
- Been thanked: 41 times
Yannr,
I tried to test your fft and matrix fft example 10.
The matrix example is strange because the Add to buffer need a STRING and data(INTEGER) is inside. If you click OK, there is a parameter1 is invalid:"Can not convert to type "string".
The matrix example cannot edit with the dspic5.5.2.1
It sound like a bug in the example+fft component
Can the matrix staff do something?
Yannr project will be a very good DSP marketing demonstration once finished here at INSA LYON...
- Has thanked: 1135 times
- Been thanked: 299 times
Hi MM!
Would not it be a good idea to make a "ver.5.5 Minor fix" or update out on the main page.
It is completely random I discover there is now a version. 5.5.2 Maybe many will never see these changes when they are deep in a thread. Just a kind suggest.
Please.
Best regard
Jorgen.
Please.
Best regard
Jorgen.
- JonnyW
Good afternoon Jorgen.
The latest build (5.5.2) should show up in the internet links if you have not upgraded, and also on the updates page accessible through Flowcode.
Difference-wise, the only change between 5.5.0 and 5.5.2 is that those with a single version can import programs from other versions with DSP components in them. We did not anticipate that this would affect enough Flowcode users to require a separate post, as this could have caused confusion so close to the original post.
Sorry if you were one who upgraded in the few days between 5.5.0 and 5.5.2 and this caused you issues - I hope everything is sorted for you now!
Cheers,
Jonny
Cheers,
Jonny
Hi Johnny!
Thank\s for your quick reply
No Problem with DSP, I havent used it yet, and I have no experience with that. I was only thinking generally, if you discovered a bug of any kind in 5.5. It would be nice like: Minor fix for 5.4 or 5.2 in main
But ok I understand now. thank you.
Have a nice evening.
Best regard Jorgen
Best regard Jorgen
- Enamul
- Has thanked: 271 times
- Been thanked: 814 times
Hi Jorgan,
I understand what you asking for. I've noticed this few days back although it posted long before and I've not updated my Flowcode yet. But as Jonny said it doesn't effect normal users. I'll make a thread if we get couple of bug in the new release. Thanks
I have made a new post on FFT and DSPIC.
You can find the new post here:
http://www.matrixmultimedia.com/mmforum ... 46&t=12009
YannR
YannR
Hi Enamul!
Glad you know what I mean. Hope you make thread if an issue should accour in 5.5 Dont hope it get so far.
Best regard
Jorgen.
Best regard
Jorgen.
- Enamul
