10 way switch bank
rrowley
Has thanked: 1 time
10 way switch bank
Post by rrowley »
I'm a new Flowcode 5 user and think the program is excellent.The videos and tutorials are really good :D
However I've hit a brick wall with this flowchart.I need to program 10 switches to LEDs where the most recent button push cancels the previous one.I managed to find an example on this and have adapted it so the first 8 switches and last two switches work as they should but I can't get the switches on different ports to cancel each other.
I've attached my flowcode and would be grateful for any ideas
Rich
10switchbank.fcf
(12 KiB) Downloaded 206 times
Re: 10 way switch bank
Hi Rich,
Can yo give the attached Flowchart a try please
10switchbank1.fcf
(12.5 KiB) Downloaded 249 times
rrowley
Has thanked: 1 time
Post by rrowley »
Hi Martin
It works perfectly.Thanks for that :) Now I can see how you've used the masking it makes sense now.
Cheers
Rich
Your welcome Rich,
Yes I used the masking, just in case you have something else that will use port D.
The Flowchart I posted will work without the masking, just the two extra outputs was required to switch the bits off when not required.
I guess I was just future proofing for you. :)
