ICD on EB185 ARM board not working
Mantas
Has thanked: 57 times
Been thanked: 27 times
Post by Mantas »
So I have received the ICD FlowKit and decided to test it. Simple program to count upwards a float variable in a while loop. I set it up as by default to B port and pins 7 and 8. Compile it, after downloading program to the chip, I switch over the switch from PROG to ICD, and then press PLAY in flowcode...soon after a message popes up saying:
[img]
(112.9 KiB) Downloaded 1696 times
[/img]
I press YES and:
[img]
(98.72 KiB) Downloaded 294 times
[/img]
Any Ideas what is wrong? Recompiling does not help...
Cheers,
Mantas
Science is my true religion.
dazz
Has thanked: 474 times
Been thanked: 458 times
Re: ICD on EB185 ARM board not working
Post by dazz »
HI
I haven't got any matrix boards but have you enabled icd in the build/project options/ icd options tab ,then send the program too chip
Dazz
Mantas
Post by Mantas »
Hello Dazz,
Yes I did. I followed the instructions in the manual...
Cheers,
Mantas
Mantas
Post by Mantas »
So I worked out, what was causing this problem...the problem was, that the switch over from PROG to ICD was causing some issues. Now I have connected two separate USB cables to different USB ports, and the switch is always left on ICD, so as soon the program is downloaded to the chip it starts working in ICD mode, but the variable watch is still an issue, all variables are 0.00000...still investigating.
Cheers,
Mantas
Mantas
Post by Mantas »
I have read some post in the forum, and found out that there should be *.cof file generated, is it also true for ARMS? Cause I can not find such file generated...
Mantas
Post by Mantas »
Hello MM,
So will anyone answer me about the COFF file?
Mantas
