How to show decimal points on a LCD
dawladin
Has thanked: 4 times
Been thanked: 1 time
Post by dawladin »
Hello mods and Flowcode experts :)
I was wondering if there was any solution to the problem that bytes dose not tolerate decimal points in calculations.
The problem im facing is quite simple i got a variable [var = var + 0.5] and i want to show the var value on a LCD.
Thanks before hand.
Regard Michael
dazz
Has thanked: 474 times
Been thanked: 458 times
Re: How to show decimal points on a LCD
Post by dazz »
Havent got much time so made a simple chart for you , create varialble as a Float, then use float to string to print string to lcd
let me know if it works
Dazz
flt to str exmp.fcf
(5.5 KiB) Downloaded 364 times
dawladin
Post by dawladin »
Thank you Dazz
It worked perfectly once again :)
Regards Michael
dazz
Post by dazz »
glad it worked
Hi Michael,
Attached is another flowchart to play with.
It's a bit more complex, but it allows you to alter at the beginning how many decimal places you require.
I believe there is a slight bug with V4 causing rounding to be simulated only. Will not round on hardware.
Works just fine on Flowcode V5 .
flt to str exmp V1 With Rounding.fcf
(7.5 KiB) Downloaded 358 times
Enamul
Has thanked: 271 times
Been thanked: 814 times
Post by Enamul »
Although I believe to deal with decimal numbers floating point and in LCD float2str is useful. But for only one or two decimal place addition and adding decimal number with byte, I must recommend normal arithmetic operation than using Float as that uses huge memory and really slow.
Rather I have put an example to show any number with one decimal point can be easily managed with addition and decision.
decimal_pt_dis_v4.fcf
(8 KiB) Downloaded 338 times
Enamul
University of Nottingham
enamul4mm@gmail.com
dawladin
Post by dawladin »
Hi guys
Thanks for the reply's :)
I was wondering what were the advantage of those 2 programs over the simple program dazz made? (I need to show 0.5,1,1.5,2,2.5,3.....)
And i got one more thing when i simulate it, it works but when i send it to the chip it wont show the decimal value eg (1.0,1.0,2.0,2.0,3.0.....)
Why is that and what can i do about im using an ATmega8-16pu.
Regards Michael
Enamul
Post by Enamul »
I have mentioned the advantage in my last post..you can't accommodate float data manipulation in small memory chip.
Also this can happen if not done carefully. Can you please post your code so that we can see?
Enamul
enamul4mm@gmail.com
dawladin
Post by dawladin »
Okay I apologize for the ignorance but im still trying to get the hang of it :)
But here is the program :)
Regards Michael
Eksamensprojekt -test-Power Failure Atmega 8.fcf_avr
(26.87 KiB) Downloaded 316 times
