ulcd-32ptu
brandonb
Has thanked: 175 times
Been thanked: 173 times
ulcd-32ptu
Post by brandonb »
i bought eblock with the old lcd, then picked up a couple of the newer ulcd-32ptu lcds http://microcontrollershop.com/product_ ... ts_id=5396 , with the new displays i only get the splash screen, does anyone know what i have to do to get these working to accept serial commands like the eblocks, i do have the 4d programming cable.... its advertised that its default serial mode
Re: ulcd-32ptu
If you look at the EB076 datasheet then there is a schematic right at the end of the document which shows how to connect up the serial interface. This should be identical for the new display.
Let us know how your getting on.
brandonb
Re: ulcd-32ptu
Post by brandonb »
ben, here's what i received in comments from 4d
SGC has been discontinued and is not available for newer displays.
4D Serial is the new Serial and ViSi Genie are new and both support being controlled as a serial slave.
Are you using some third party library with flowcode5?
If so, where did it come from?
If not, the commands will still need writing, they will just be different to what you wrote before.
EDIT: wanted to add fix link for this from another post http://www.matrixmultimedia.com/mmforum ... a6d#p47079
