PIC18F46k80 Could Not ID chip & NOT erased
georgedd
Been thanked: 1 time
Post by georgedd »
When attempting to use a PIC 18F46k80 with the EB-006-00-7 Multiprogrammer using an external PSU (13.5v) after a successful compilation and linker/assembler and then after Launching the programmer the Matrix PICmicro Programmer displays "Could Not ID the onboard chip - assuming it is the one specified in the configuration screen, i.e. PIC18F46K80". After "OK"ing this I received "PICmicro has not been erased. Continue?"
(The EB-006-00-7 states: Supported devices: 18F Devices & PIC18F46K20, PIC18F4680 PLUS Flowcode V4 version = v4.5.18.74 includes 18F46K80 therefore I assume the 18F46K80 should work with this setup)
Please help.
Re: PIC18F46k80 Could Not ID chip & NOT erased
I'm afraid the EB006 cannot currently reprogram the 18FxxK80 devices. You should be able to reprogram the device by getting a Microchip PICkit and plugging this into the ICSP header on the EB006. Same goes for the 18fxxK22 and the 16F7x7 device families.
Details of how to setup a PICkit programmer within Flowcode are available from here.
http://www.matrixmultimedia.com/support ... f=68&t=786
georgedd
Post by georgedd »
Used PICkit 3 and upgraded to Flowcode V5 For PIC.
Now working fine.
Thanks,
George.
