Steve,
Is this all sorted now? If so I may have a look at my implementation to see why it did not work for me.
Are the amendments all in v3.1?
Mark
PIC12F629 configuration/program memory failed; PIC16F648A ok
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
I don't think it is, Mark.
For me, unselecting the "Use IncXCmd" option solved the problem. But I don't think it did for Michael.
It could be that I have a newer version of the PPP software on my PC. I will have a look at this here this afternoon on a clean install of Flowcode to see if this also has the problem.
Hi Steve,
I have the same problem, I've written some very simple LED flashing code in Flow 3.1.0.31 with remarkably similar results. I've also tried with other hex code written with MPLAB and downloaded via PPPv3 (ver. 3.8.11.24), same result i.e. chip not programmed. In each case the "Use IncXCmd" option was disabled.
Could you send me the "new" .fcd file and I'll try that.
I've also noticed that after several programming attempts the autodetect button in PPP fails to ID the PIC. After that a full erase sometimes brings the PIC back to life but sometimes not and I'm getting a little fed up, I've lost two now and they're not that cheap!
Best regards,
Nick
Best regards,
Nick
I have had a good play around with the 12F629 here using the Matrix hardware, PPP 3.9 and Flowcode V3.2. I was unable to program the PICmicro until I changed the retain OSCCAL option to unticked.
To do this I opened Flowcode and clicked Chip -> Configure -> Options and unticked retain OSCCAL value.
Then once the chip was programming ok I tested every aspect.
I/O Pins, Internal Osc, Internal MCLR, Auto ID etc. Every programming cycle works correctly and there have been no problems.
If this is not what you are experiencing then please let me know.
