Hi all.
Kindly help me in this regards. I cannot copile my program showing an error that it contains c code but i dont know where it is. Also it shows this pic dont have eeprom memory. help me pls.
Here I'm adding the Flow code file.
CANNOT COMPILE MY PROGRAM
Re: CANNOT COMPILE MY PROGRAM
Hi karthik.devaraj,
This is the second time you have posted in Programming tips and tricks section.
As stated here:
http://www.matrixmultimedia.com/mmforum ... 91&p=49376
Programming tips and tricks section is not for questions or technical support.
I have moved your post to a more suitable section.
I will be moving this post tomorrow to V5 section. (will leave post in General section today so you can have the chance to respond)
To gain access you will need to be a V5 registered user.
Here is a link for you to follow which will allow you to register:
http://www.matrixmultimedia.com/mmforum ... =46&t=9958
If you register then you will receive better support.
As stated here:
