Patch set #3 can now be downloaded here:-
http://www.matrixmultimedia.com/temp/FC ... hSet_3.exe
Note: Patch sets are cumulative - You only need to install the latest version of the patch to bring your files up to date.
Flowcode v6 Open Beta - Patch Set 3
- Jordy101091
- Has thanked: 25 times
- Been thanked: 188 times
Re: Flowcode v6 Open Beta - Patch Set 3
Just installed patch#3,
It now works and compiles as it should be.
Thanks for the quick fix.
Regards Jordy
Regards Jordy
- JonnyW
- Has thanked: 63 times
- Been thanked: 290 times
Good to hear. It always seems to be the way that kind of thing happens right before a release!
Jonny
Jonny
- JohnCrow
- Has thanked: 364 times
- Been thanked: 716 times
Patch3 still not working to start with - But now solved
Hope this post may help anyone who is still having problems
After Patch 3 I could still only compile PIC8 & PIC16.
I tried a clean install of FC6 and the new patch file on the laptop, no fc6 at all (Disc imaging is great for finding problems).
This worked fine, all chip types will compile to Hex.
I have uninstalled on the main system and deleted the registry entries.
Reinstall FC6, activate, install patch 3.
All now seems to work ok.
Ive attached the test files and error message files.
Thanks Guys latest patch is great.
