BUG: Error when using CAN and FAT
Please add any bug reports that require discussion here
Forum rules
Only bug reports will be considered here. General questions should not be posted in this forum.
Jordy101091
Has thanked: 25 times
Been thanked: 188 times
Post by Jordy101091 »
I'm getting an error when I use a CAN component and a FAT component I the same Flowcode,
It gives an error that has something to do with a prescaler.
Target folder: \\NASHJJAKL\Jordy Kleian\D6ULV5~V\FKZ0BJ~O\PB83OU~D\AY92OP~W\FY6XBH~1.0\Test
Source name:   \\NASHJJAKL\Jordy Kleian\Documenten\Flowcode Projects\Projecten\Aquarium Automatics\Firmware v1.0\Test\Test2.fcfx
Title:
Description:
Device:        PIC.18F.18F6722
Generated by:  Flowcode v6.0.0.60
Date:          Saturday, August 31, 2013 22:52:00
Users:         0
Registered to: 30day_62150048
Licence key:   H9023P
   NOT FOR COMMERCIAL USE
Launching the compiler...
C:\Program Files (x86)\Flowcode 6 Beta\compilers\pic\boostc\boostc_18F.exe  -v -t PIC18F6722 "Test2.c"
Launched program C:\Program Files (x86)\Flowcode 6 Beta\compilers\pic\boostc\boostc_18F.exe
Launching BoostC...
BoostC Optimizing C Compiler Version 7.11 (for PIC18 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2013 Pavel Baranov
Copyright(C) 2004-2013 David Hobday
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC18 max code size:Unlimited, max RAM banks:Unlimited
Test2.c
Starting preprocessor: "C:\Program Files (x86)\Flowcode 6 Beta\compilers\pic\boostc\pp.exe" Test2.c -i "C:\Program Files (x86)\Flowcode 6 Beta\compilers\pic\boostc\include" -d _PIC18F6722 -la -c2 -o Test2.pp -v -d _BOOSTC -d _PIC18 -d _CHAR_INDEX
C:\Program Files (x86)\Flowcode 6 Beta\CAL\PIC\PIC_CAL_SPI.c(69): Illegal redefinition of symbol: MX_SPI_PR_SCALE_X
1 errors detected
Error: preprocessing error
failure
Completed BoostC compilation, return = 1
C:\Program Files (x86)\Flowcode 6 Beta\compilers\pic\boostc\boostc_18F.exe reported error code 1
FINISHED
Hope this bug will be fixed soon,
Regards Jordy
PS. I cannot upload C code file its to big 264KiB my limit is 256KiB
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: BUG: Error when using CAN and FAT
Post by kersing »
Hi Jordy,
You could put the C file in a ZIP archive. Usually C files compress to a fraction of their original size.
Jac
― C.S. Lewis
Hi Jordy,
This file fixes the issue and will go into the release. Simply pop it into your "Flowcode Beta/CAL/PIC" folder to apply the changes.
PIC_CAL_SPI.c
(11.82 KiB) Downloaded 435 times
Thanks for the spot.
