Jump resistor with I/O ports
For users of Matrix Multimedia Electronics software to discuss projects, circuits and any other electronics concepts.
Klipeti
Has thanked: 1 time
Post by Klipeti »
Can I use 1ohm jump resistor with I/O ports or any other ports? I don't have 0ohm jump resistors.
Goal is to make clean looking circuit board, plain wire would look stupid in middle of other components.
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: Jump resistor with I/O ports
Post by kersing »
That depends on the load. If there is no significant load the voltage drop will be minimal and you're fine using 1 ohm.
― C.S. Lewis
Klipeti
Has thanked: 1 time
Post by Klipeti »
Ok thanks. I think that I just get 0ohm resistors -> better sure than sorry :)
Brendan
Has thanked: 140 times
Been thanked: 118 times
Post by Brendan »
Just thought I'd mention that the limited output current of an I/O port renders effective source resistance typically around several tens of Ohms. This can be determined by the quoted output voltage drop versus output current for high and low conditions in the electrical characteristics of the device datasheet.
Consequently, an additional series resistance of 1-Ohm would have no bearing under any circumstances. :)
All the best,
Brendan
