eeprom compiler error v6.0.4.0
Peter Bonder
Been thanked: 1 time
Post by Peter Bonder »
hi,
I installed FC6. Now I can't compile flowcode. In V5.x I had no problems
Please have some advice...
  • Date: Thursday, January 02, 2014 11:35:53
    Users: 1
    Registered to: Peter Bonder
    Licence key: xxxxx
    De compiler wordt gestart...
    C:\Program Files (x86)\Flowcode 6\compilers\pic16\batchfiles\pic16_C30_comp.bat "D:\FLOWCO~2\Flowcode1" "D:\FLOWCO~2\" "30F3014"
    Launching compiler...
    D:\FLOWCO~2>pic30-gcc -c -mcpu="30F3014" -funsigned-char -fno-short-double -Os -I"C:\PROGRA~2\FLOWCO~2\COMPIL~1\pic16\BATCHF~1\..\support\h" -I"C:\PROGRA~2\FLOWCO~2\COMPIL~1\pic16\BATCHF~1\..\MX_support" -Wall -std=gnu99 "D:\FLOWCO~2\Flowcode1".c -o "D:\FLOWCO~2\Flowcode1".o
    In file included from C:\Program Files (x86)\Flowcode 6\CAL\includes.c:119,
    from D:\FLOWCO~2\Flowcode1.c:95:
    C:\Program Files (x86)\Flowcode 6\CAL\/PIC16BIT\PIC16BIT_CAL_EEPROM.c: In function 'FC_CAL_EE_Read':
    C:\Program Files (x86)\Flowcode 6\CAL\/PIC16BIT\PIC16BIT_CAL_EEPROM.c:54: error: 'eeprom' undeclared (first use in this function)
    C:\Program Files (x86)\Flowcode 6\CAL\/PIC16BIT\PIC16BIT_CAL_EEPROM.c:54: error: (Each undeclared identifier is reported only once
    C:\Program Files (x86)\Flowcode 6\CAL\/PIC16BIT\PIC16BIT_CAL_EEPROM.c:54: error: for each function it appears in.)
    C:\Program Files (x86)\Flowcode 6\CAL\/PIC16BIT\PIC16BIT_CAL_EEPROM.c: In function 'FC_CAL_EE_Write':
    C:\Program Files (x86)\Flowcode 6\CAL\/PIC16BIT\PIC16BIT_CAL_EEPROM.c:77: error: 'eeprom' undeclared (first use in this function)
    Error returned from [pic30-gcc.exe]
    Completed compilation, return = 1
    C:\Program Files (x86)\Flowcode 6\compilers\pic16\batchfiles\pic16_C30_comp.bat gerapporteerde foutcode 1
    KLAAR
Re: eeprom compiler error v6.0.4.0
Hello Peter,
Thanks for the spot, I have found the cause of the problem and think I have now managed to resolve it.
To solve the issue you should just have to copy the attached file below into your "C:\Program Files (x86)\Flowcode 6\CAL\PIC16BIT" directory.
(2.97 KiB) Downloaded 264 times
Let me know how you get on.
Peter Bonder
Benj,
Thank for you quick respond!!!
problem seems to be solved, although I have not tested live with a device.
think it will be okay
thanks again!!
Peter Bonder
Netherlands
