What compiler to use
Desdewit
Has thanked: 25 times
Been thanked: 11 times
Post by Desdewit »
Does the latest version of FC5 still need Hi-Tech C to compile pic 18f46j50 code or will the standard boost c do the trick?
Re: What compiler to use
Hi Desdewit,
SimPLC RTCC V1.0a.fcf (using 18F46J50) compiles with Flowocde V5.5.2.1 and boost C without any errors.
Not got the hardware to test with.
Desdewit
Post by Desdewit »
Hallo Martin
Thanks for checking.
My version isV5.5.0.1 (22.01.13) but when I check for updates the program respond with "Your version of Flowcode_PIC is up to date".
How can I update to V5.5.2.1?
Hi Desdewit,
If you go to:
http://www.matrixmultimedia.com/flowcod ... nloads.php
You will have to enter the last two sections of your license key including the dash.
That should allow you to download the latest version.
