Simple output 2
For C and ASSEMBLY users to post questions and code snippets for programming in C and ASSEMBLY. And for any other C or ASM course related questions.
ukweb
Simple output 2
Post by ukweb »
I have added the code adcon1=0x07 to it, but even then it doesn't work
Matrix Multimedia board PIC 16f876
#include <system.h>
main()
set_bit(STATUS, RP0); //SELECTS BANK 1
TRISB=0x00;  //MAKES PORTB OUTPUT
TRISA=0xff;  //MAKES PORTA INPUT
clear_bit(STATUS, RP0);  //SELECTS BANK 0
adcon1=0x07;
if(input_pin_port_a(0))
PORTB=0xff;
else
PORTB=0x00;
The above code should be turning all leds connected to PORTB on when bit 0 of PORTA is set, otherwise turned off.
And also i have know what the oscillator setting should be for this. XT or RC or HS.
Ian
Been thanked: 1 time
Post by Ian »
Try with adcon1 the very first thing, before the TRISA stuff.
XT, HS (XT setting on board) and RC (RC setting on board) need to match in the config and the board clock switch, but should work in either. RC may be very slow for some stuff, but works well with basic tutorial type programs.
Check Watchdog is off as that can keep resetting programs.
Has thanked: 114 times
Been thanked: 422 times
Post by Steve »
The adcon1 register is in bank 1, so you need to set its value when the RP0 bit of the status register is set, ie:
#include <system.h>
main()
    adcon1=0x07;             //Set all A/D i/o lines to digital
        PORTB=0xff;
    } else {
        PORTB=0x00;
