tmr1 and tmr1 ext osc
brandonb
Has thanked: 175 times
Been thanked: 173 times
Post by brandonb »
at least with 16f1939 when enable tmr1 it cuts out useage of c0,c1 pins... the problem is when select instruction clock as source it should clear bit 3 in t1con register... after enable tmr1 put this line of code afterwards to regain control of c0,c1 pins
t1con&=~(1<<3);
Kenrix2
Flowcode v5 User
Has thanked: 72 times
Been thanked: 177 times
Re: tmr1 and tmr1 ext osc
Post by Kenrix2 »
Thanks for pointing this out. Enamul has previously posted a permanent solution detailed here:
http://www.matrixmultimedia.com/mmforum ... +st#p41728
brandonb
Post by brandonb »
thanks, i didn't realize, a while back i discovered this problem and there was no fix, then i learned how to read datasheets, was adding tmr1,3,5 to libraries tonight and figured would post that
