EB006 V9 ADC confusion. [SOLVED]
Attached is a simple Flowchart that works on EB006 V7
Turning pot connected to PortA1 (An1) from min to max causes LCD to change from 0 to 255 as expected.
Connect hardware to EB006 V9 then send same flowchart then:
Turning pot connected to PortA1 from min to max causes LCD to change from 0 to 1 Not as expected!
When display is showing 1, the voltage measured on pin 3 of 16F1937 is 4.87V
Anyone else seeing this or is it just me?
What makes this even more odd is if I used a 16F1937 on Eb006 V7 ADC works fine.
If I use 16F877A in EB006 V9 ADC works fine.
So that's why I'm confused.
ADC 16F1937 Test2.fcfx
(5.59 KiB) Downloaded 274 times
LeighM
Has thanked: 481 times
Been thanked: 699 times
Re: EB006 V9 ADC confusion.
Post by LeighM »
That is odd, works OK on the EB006 V9 and 16F1937 I have.
Leigh
Re: EB006 V9 ADC confusion. [SOLVED]
Thanks Leigh,
The issues was caused by a faulty ADC on the 16F1937 itself.
Reason why It appeared to work on a V7 programmer is I must have inadvertently placed my other target device in my old programmer as the chips were placed near each other.
Benj & I came to that conclusion this evening while Ben was testing all the possible scenarios.
Thanks for your help Ben it is appreciated. :)
