eblock inputs : not working
steven007
Post by steven007 »
We just started working with E-blocks, and flowcode 4.
For some reason, we cannot get any input working, Both switches ( EB0070 001 and EB0074 ) on all possible input ports don't work.
Any Ideas what we are doing wrong ?
We have the 16F877A microcontroller.
Are there demo programs available somewhere ?
Re: eblock inputs : not working
This should be straightforward enough to do. Are you wiring a connection from the +V terminal on the Multiprogrammer to the +V terminal on the switch E-block?
Have you done the 1 second led flash test?
You many not have set configuration settings up properly e.g watchdog timer and low voltage programming disabled etc.
Take a look at this post.
