Compare str$
MarkW
Flowcode v5 User
Has thanked: 3 times
Been thanked: 11 times
Compare str$
Post by MarkW »
Can anyone tell me if the strings that are being compared need to be same array size?
Lets say str1 has array size of 10 elements and str2 has array of 5 elements. Will the
compare str$ function work? Help files dont really elaborate too much on that.....
Thanx
Mark
Re: Compare str$
Hi Mark,
Yes strings of different lengths can still be compared and should work fine as long as there is room in both the string variables for the null termination.
Let me know if you have any problems.
MarkW
Flowcode v5 User
Re: Compare str$
Post by MarkW »
Thanx, will give that a try.....will post results for others to see.
Mark
