frequency counter & generator
ardiles
Has thanked: 7 times
Been thanked: 1 time
Post by ardiles »
i have a TMR2 to count frequency...TMR2 becouse i use TMR1...
more than 41Hz to change a variable(and disable one function), and below 41Hz to change same variable who changed more than 41Hz and enable a function...
i tryed to modify an example » 5. Digital frequency counter.fcf, and i failed... :roll:
thanks!
ardiles
Re: frequency counter & generator
Post by ardiles »
i tryed the explain of BENJ but failed 2....
Hi ardiles,
Are you're using V5 professional version of flowcode?
If so can you please sign up to be a V5 registered user by following this link
Once registered, we should be able to assist you further.
ardiles
Post by ardiles »
Hi Martin! i not use "Flowcode V5 professional", i am using "Flowcode V5 for PIC free version".
i am not professional programmer, i am amateur!
i must make a pin of microcontroler like this:
0-41Hz - turning on a LED,
more than 41Hz - turning off a led...
!! frequency range is variable and total range is: (10 - 290)Hz -
is signal of speed vehicle:
Semnalul este dreptunghiular. Pentru
10km/h - 13.85Hz,
20-27.75
30-41.65
40-55.55
50-69.4
60-83
70-97.2
80-111.1
90-125
100-138.85
110-152.75
120-166.65
130-180.55
140-194.4
150km/h-208.3Hz
Hi ardiles,
ardiles wrote:i am not professional programmer, i am amateur!
You don't have to be professional programmer to use professional version.
Hobbyists (including complete beginners) use professional as that enables them to use all the communications components and not be restricted to amount of memory that can be used.
What microcontroller are you using?
ardiles
Post by ardiles »
Hi Medelec35,
uc is 16f88, and the electronics for me is hobby...thats the reasoon who i dont use propessional version...
i am to level: 3inputs and 4 outputs, PWM on CCP1 or 2, and another small knowledge...
but there is another discuttion!
i try to modify an example 5.frequency counter! and i succeed to make output to be on <10Hz and afther this threshold turn off the output....
BUT: the ehample have 16x2 display, and i dont use the display! when i delete the display and it connections, the example 5.frequency counter, DONT WORK :oops:
dazz
Has thanked: 474 times
Been thanked: 458 times
Post by dazz »
Hi ardiles
Martin has asked you very politely to sign up to the V5 forums (link in my sig) ,So please can you sign up as this is in the wrong forum
Dazz
ardiles
Post by ardiles »
HI Dazz!
sorry for the wrong posting(V2 & V3)... :idea:
dazz
Post by dazz »
No worries again please sign up to the correct forums ,as the Vc's and others who help do this voluntarily and as such our time available to help others is limited, so help us to help you,It's very difficult to offer help if people wont sign up and/or post in the correct section
Kindest Regards
Dazz
ardiles
Post by ardiles »
Hi!
i know my post is in wrong section but, this file can be usefully to users who want a fcf work like my description...
frecventa.fcf
<41Hz works, >41Hz disable
(15.06 KiB) Downloaded 698 times
Since Flowcode V5 professional was used to modify posted frecventa.fcf Flowchart, I have moved topic to the correct section.
