Accurate Temperature Thermometer using LM35
Equipment used and files required:
EB006 Programmer with 16F1824 fitted.
Note: Only designed to work with the following microcontrollers:
12F1822, 16F1823, 16F1824,16F1825, 16F1828 & 16F1829
Also External Vref will no be available unless original PIC_CAL_ADC.c is restored.
EB005 LCD.
LM35 Temperature sensor (10mv per deg C) connnected to An0 (pin 13)
Connections: If readings fluctuate, then a basic RC filter (see Datasheet)
Attached Thermometer LM35 V1.fcfx
Description:
The 16F1824 (and all shown devices above) have many new features including 3 different internal stabled Fixed Voltage References (FVR)
These are:
1.024V which changes 10 Bit ADC resolution to 1.024/1024 = 1mV
2.048V which changes 10 Bit ADC resolution to 2.048/1024 = 2mV
& 4.096V which changes 10 Bit ADC resolution to 4.096/1024 = 4mV
Now you can see the reasoning behind this since without FVR and supply =5V
10 Bit ADC resolution = 5/1024 = 4.88mV
The down side is since each ADC variable increment of 1 = 1mV then maximum i/p voltage for ADC = 1023 = 1.023V = 102.3 deg C
PIC_CAL_ADC.c has been modified to enable internal Fixed Voltage reference of 1.024V as this makes the thermometer much more sensitive!
But only when Vref+ has been selected from Vref options (ADC component properties)
If not, then the default resolution will be 4.88mV: This means when FVR is enabled the resolution of 10bit ADC is 1.024/1024 = 1mV
Since output voltage from LM35 is 10mV per deg C that means that the resolution of temperature Thermometer is 0.1 deg C
Floats are not required to display temperature to an accuracy of 0.1 deg C
How the flowchart works is:
10Bit ADC is read.
Since voltage out from LM35 is 10mV per C and resolution of ADC is 1mV then ADC = temperature x 10
So if ADC= 151 then actual temperature is 15.1 deg C.
The 151 is converted to a string.
All numbers except from the last number on the right is printed so in this case 15
Then decimal point is printed. Finally the last digit on the right is printed.
The result printed will be 15.1
At the time of writing this, being in a warm room, calibrated Ktype thermometer displayed 27.0 deg C and LCD connected to EB006 programmer with LM35 connected displayed 26.9 deg C
Hope you find this useful.
EB005 LCD.
Description:
These are:
10Bit ADC is read.
- Themometer LM35 V1.fcfx
- (8.02 KiB) Downloaded 1364 times
Reason: Removed PIC_CAL_ADC.c. See post below (Dated Wed Dec 02, 2015 7:23 pm) for further details.
Re: Accurate Temperature Thermometer using LM35
If anyone wants to use the above method on a different target device (with internal fixed voltage reference), then let me know and I will see what I can do.
No sorry.
This method will only work on devices with:
so it's for the newer devices e.g xxF18xx
If you're not sure if it will work or not with a target device, then the simplest way would be to go to Microchip website
Enter your microcontroller in the Search for Data Sheets box
Then load data sheet.
When loaded hold Ctrl then press F
Enter
If there are instances of 1.024v and FVR then your target device is probably compatible.
Fixed Voltage Reference (FVR) with 1.024VIf you're not sure if it will work or not with a target device, then the simplest way would be to go to Microchip website
Enter
1.024vMartin
Sanjay Singh
- Has thanked: 10 times
- Been thanked: 3 times
Dear Medelec,
I wanna use 16F1938 & 16F1939, which has FVR of 1.024V on it. The ADC input will be AN0 or AN1
Please help me out in this matter.
Sanjay
Sanjay
Hi Sanjay
Please help us to help you, follow the steps in martins post above yours, once done let us know if you still need help, also let us know what you have done and specifically what you need help with
Dazz
Dazz
It's best not to use PIC_CAL_ADC.c as it could be replacing an updated version.
I will post some additional steps to modify PIC_CAL_ADC.c with correct values as soon as i get the time.
Hopefully will be tonight but no promises.
Not got LM35 anymore so cant test on hardware but as promised here are some details.
Run text editing software like notepad or notepad++ in admin mode.
Use text editing software to load C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_ADC.c
If 64 bit windows
or
C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_ADC.c
If 32 bit windows
Search for your target device then look for if (Vref != 0) just below all the #ifdef MX_ADC_CHANNEL_
Then immediately after place
There will be a statement below e.g:
on the next line down place the following:
so for:
// ADC Type 18 Supported Devices ***********************************************************
// 16F722, 16F723, 16F724, 16F726, 16F727, 16F1933, 16F1934, 16F1936, 16F1937, 16F1939
For example you should have:
Not sure if that is how Ben intended FVR to be implemented or not as I believe PIC_CAL_ADC.c was to be modified for such a purpose?
If 64 bit windows
or
If 32 bit windows
if (Vref != 0)Code: Select all
{Code: Select all
adcon1 = adcon1 | (Vref & 0x03);Code: Select all
fvrcon=fvrcon | 0xC1; }// ADC Type 18 Supported Devices ***********************************************************
if (Vref != 0){
alikimiafar
- Has thanked: 1 time
hi
what I can do ? to chose internal fixed voltage reference , fvr 2.048 for 18f26k22 in flowcode6
