Possible PIC16 SPI issue
A forums to allow bugs and problems with Flowcode v6 to be reported and resolved.
GTF
Has thanked: 20 times
Been thanked: 52 times
Post by GTF »
dsPIC33EP512MU810 datasheet note states, "The SMP bit must be set only after setting the MSTEN bit. The SMP bit remains cleared if MSTEN =0" http://ww1.microchip.com/downloads/en/D ... 70616g.pdf (p.341)
PIC16BIT_CAL_SPI.c assigns the value of SMP prior to setting MSTEN. Hence, it appears that Input data is always sampled at the middle of data output time, even if "END" is selected in the SPI component properties.
LeighM
Has thanked: 481 times
Been thanked: 699 times
Re: Possible PIC16 SPI issue
Post by LeighM »
Thanks for the spot.
I've updated the CAL file (and attached)
PIC16BIT_CAL_SPI.c
(15.43 KiB) Downloaded 254 times
