Connection problem with EB066
juliantong
Been thanked: 1 time
Post by juliantong »
Dear friends~ I got a EB066 GSM block yesterday, and plug to my pervious EB006 with 16F1937 on board multiprogrammer. I followed the factory test routine to connect them, not transfer the GSM.hex to EB006, but transfer the phone_04.fcf by Flowcode-V5 to EB006.
However, the GSM block seems dose not work all the time (The led on EB066 never flash, but I acturally can hear a sound from the head set, which like 'mi fa so' musical notes). That is the problem I met. :cry:
what should I do, please help me. next week is the due of my midterm report of FYP, with many thanks.
Re: Connection problem with EB066
The latest EB066 boards will not flash the LED by default, you must send this AT command in your program to start the LED flashing.
AT#SLED=2
Here is our test routine for the board which contains the LED flash command.
GSM_Test2.fcf
(39.71 KiB) Downloaded 426 times
Let us know how you get on.
juliantong
Dear Benj
I am sorry. I think the GSM_Test2.fcf you send to me does not solve my problem.
If I use Flowcode V5 to compile and transfer it to chip, result shows that:
% program memory check failed %
% (NOTE: if the PIC is code-protected, this message will be %
% displayed even if the program has been sent correctly) %
% That took 13.369 seconds %
But actually, I did disable the code-protected in PPP
If I use Flowcode V6 to compile and transfer it to chip, result turns:
% GSM_Test2_v6.c : 1 : error : Too few parameters: v5__gsm0::ReadString %
% GSM_Test2_v6.c : 2046 : error : Too few parameters: v5__gsm0::ReadString %
Below it the components I have, as well as the connection. Hope you can help me to check that's wrong with my operation or programming setting.
Components:
1. EB-006-00-8, 16F1937 (USB power supply);
2. EB014-00-1 (PORT D);
3. EB066-00-2 (PORT C);
4. EB-005-00-3 (PORT B);
(actually, I have a EB066-00-1, which working correctly, but receiver can not hear what I said during voice call connection. so, I want use EB006-00-2);
Connection:
+V on EB-006-00-8 to +V of LCD and GSM;
+14V to VPWR of GSM;
The program was setup for a 16F877A chip so I have changed it to a 16F1937 for you now which is why you are getting the memory check errors. Hopefully the v5 program should now work and the v6 program will need a slight change to add the missing parameter to overcome the compile error.
GSM_Test2.fcf
(39.75 KiB) Downloaded 406 times
juliantong
Dear Benj
thanks a lot and sorry for reply so late, and may interrupt your holiday. now Flowcode v5 can compile and transfer GSM_Test2.fcf to chip with no question, but the LCD keep display just like following figure. (After display 'starting' string)
I cannot fully understand all the flowcharts in your file, and also don't know my new GSM board can work or not. I can ensure my SIM card is suitble, beacuse it can work on EB066-1. because I only have 16F1937, so the official test routine is not help, want can i do now?
