String Manipulation error
- Has thanked: 1 time
- Been thanked: 26 times
hallo
if i have a String Manipulation window with :
text_01 = "1234123412341234"
i get this
Error: Unresolved external function:'FCI_CONCATENATE(unsigned char*,unsigned char,unsigned char*,unsigned char,unsigned char*,unsigned char)'
Error: Unresolved external symbol, function:FCI_CONCATENATE
Failure
Return code = -2
Flowcode konnte die ASM-Datei nicht assemblieren, da folgende Fehler auftraten:
FINISHED
Thanks for your help.
wolfgang
i get this
Failure
Return code = -2
FINISHED
wolfgang
Hallo
The same problem with orginal Tut_32
If i test the code with the simulator it is ok (the same with my one code)
If i push the kompiliere to c no problem.
If i push the kompiliere to asm i have the error
Ihave work with tostring$[] i have also the error
File name: C:\Programme\Matrix Multimedia\Flowcode V3\Examples\Tut_32.c
Generated by: Flowcode v3.1.0.31
Date: Sunday, April 01, 2007 11:36:51
Licence: Professional
Registered to: sachs wolfgang
Launching the compiler...
BoostC Optimizing C Compiler Version 6.52 (for PIC16 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2006 Pavel Baranov
Copyright(C) 2004-2006 David Hobday
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC12,PIC16 max code size:Unlimited, max RAM banks:Unlimited
Tut_32.c
Starting preprocessor: "C:\Programme\Matrix Multimedia\Flowcode V3\BoostC\pp.exe" "C:\Programme\Matrix Multimedia\Flowcode V3\Examples\Tut_32.c" -i "C:\Programme\Matrix Multimedia\Flowcode V3\BoostC\include" -d _PIC16F88 -la -c2 -o Tut_32.pp -v -d _BOOSTC -d _PIC16
Tut_32.c success
success
Return code = 0
BoostLink Optimizing Linker Version 6.52
Error: Unresolved external function:'FCI_LEFTSTRING(unsigned char*,unsigned char,unsigned char*,unsigned char,unsigned char)'
Error: Unresolved external function:'FCI_COMPARE(unsigned char*,unsigned char,unsigned char*,unsigned char,unsigned char)'
Error: Unresolved external symbol, function:FCI_LEFTSTRING
Error: Unresolved external symbol, function:FCI_COMPARE
Failure
Return code = -2
FINISHED
wolfgang
Tut_32.c
Tut_32.c success
success
Return code = 0
Failure
Return code = -2
FINISHED
wolfgang
Hallo Steve
Yesterday night I fight with my flocode.....
After i change in the "compiler option" all *.pic16 to *.pic18
it works OK.
Question:
If I change the "chip type" must i change the "compiler option" by hand?
Before this,i think all settings change automatically if i change the
chip type.
wolfgang
it works OK.
Question:
chip type.
wolfgang
...error
Hallo
in the newest version i must also change the compiler-version.
After installing Flowcode,the option:
-ld "C:\Program Files\SourceBoost\lib" libc.pic18.lib "%f.obj" -t PIC%p -d "%d" -p "%f"
I have nothing in these subdirectory Program Files !!
but in Programme.
If i change to:
-ld "C:\Programme\Matrix Multimedia\Flowcode V3\BoostC\lib" libc.pic18.lib flowcode.pic18.lib "%f.obj" -t PIC%p -d "%d" -p "%f"
it is ok
Regards wolfgang[/list]
but in Programme.
If i change to:
it is ok
Hello Wolfgang
I think that the linker options may get corrupted after installing the patch / latest install on certain machines. This problem can be automatically fixed by clicking the restore defaults button in the compiler options window.
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
I'm not sure why this has gone wrong. Is anyone else having the same problem?
If anyone is interested, this is what is happening...
On installation, Flowcode sets the following registry key with the compiler setting defaults:
For example, the "DefaultAssemblerSwitches" entry gets set to:
(where [INSTALLDIR] is the installation directory selected during installation - by default, this is %PROGRAM_FILES%\Matrix Multimedia\Flowcode V3").
When Flowcode runs, it gets its compiler settings from the following location:
If these settings do not exist, then the ones in HKEY_LOCAL_MACHINE are used instead. If these are also empty, then Flowcode will use some hard-coded defaults instead.
If you ever change the settings in the "Compiler Options" window, these new settings are stored in the HKEY_CURRENT_USER area.
Clicking on the "Restore Defaults" button will copy the settings in HKEY_LOCAL_MACHINE (or from the hardcoded defaults) to HKEY_CURRENT_USER.
HKEY_LOCAL_MACHINE\SOFTWARE\MatrixMM\FlowCodeV3\DefaultCompiler
-ld "[INSTALLDIR]BoostC\lib" libc.pic16.lib flowcode.pic16.lib "%f.obj" -t PIC%p -d "%d" -p "%f"
HKEY_CURRENT_USER\Software\matrixmm\FlowCodeV3\Compiler
...error
Hallo Steve
I look in the registry there are the the same as you say,
but i press the "Restore Defaults"
then there is a ather one.
d "%d" -p "%f"
[/list][/list]
d "%d" -p "%f"
[/list][/list]
