Hi all
is there a list specifying what math functions are available in flowcode ?
cheers
joe
math ability
Re: math ability
Hi Joe
Here is the list of functions taken from the latest help file.
( ) - Parentheses.
= <> -Equal to, Not equal to.
+ - * / MOD - Addition, Subtraction, Multiplication, Division & Modulus.
< <= > >= - Less than, Less than or equal to, Greater than, Greater than or equal to.
>> << - Shift right, Shift left.
NOT AND OR XOR - NOT(inversion), AND, OR, Exclusive OR
Functions (Flowcode for ARM only)
Flowcode includes an additional set of mathematical functions:
fabs( x ), floor( x ), ceil( x ) - absolute value, floor and ceiling functions
round( x ) - decimal rounding (x rounded to the nearest integer)
fround( x , y ) - floating point rounding (x rounded to y decimal places)
fmod( x , y ) - floating point modulus (remainder of x divided by y)
sqrt( x ), cbrt( x ) - square and cube roots
log( x ), log10( x ) - logarithms (base e and base 10)
exp( x ), pow( x , y ) - exponential and power functions (x to the power of y)
sin( x ), cos( x ), tan( x ) - trigonometric functions
asin( x ), acos( x ), atan( x ), - inverse trigonometric functions
atan2( y , x ) - four-quadrant inverse tangent
sinh( x ), cosh( x ), tanh( x ) - hyperbolic functions
asinh( x ), acosh( x ), atanh( x ) - inverse hyperbolic functions
fact( x ) - factorial
random( ) - random number between 0 and 32767
isnan( x ), isinf( x ) - tests for not-a-number and infinity
( ) - Parentheses.
Re: math ability
I've just downloaded the trial version of Flowcode v6.I tried to use the Calculation component but got a compiling error when I entered tanh().Simmilarly with sinh()
Why is this?
I circumvented the problem by the successful use of exp(). Is this an intended limitation of the trial version?
Why is this?
Re: math ability
The 8-bit PIC version of Flowcode supports Float variables but not the float functions such as tan and tanh. We are currently looking into switching compilers for 8-bit PIC to remove this problem.I've just downloaded the trial version of Flowcode v6.I tried to use the Calculation component but got a compiling error when I entered tanh().Simmilarly with sinh()
Why is this?
All other variants of Flowcode, ARM, AVR and 16-bit PIC should work fine with the floating point functions.
stuart randall
Re: math ability
Hi Ben, this is something I'm having trouble with now. I see that its been about 6 months with this post and I was wondering if there have been any developments with it?
Re: math ability
Hello Stuart,
No this compiler change has now been pushed back to Flowcode 7 which is still a fair way off. Can you switch to another microcontroller family for now?
stuart randall
Re: math ability
I could do. I'm currently using a 16F1937. Is there a similar device you can recommend?
Re: math ability
Hello Stuart,
How about a ATMEGA328P (chip used commonly on Arduino) or a dsPIC33EP device (same family as we use on the ECIO40P16 device).
