Problem with Mid$
A forums to allow bugs and problems with Flowcode v6 to be reported and resolved.
gtc
Has thanked: 30 times
Been thanked: 15 times
Problem with Mid$
Post by gtc »
According to the documentation:
Mid$(string,start,size)
Retrieves a substring from the string, starting at position start of size characters.
However, when I use Mid$ in Flowcode 6.0.2.1, as follows, where string A[20] has the value "123456789" :
Result = Mid$ (A,X,1)
Result[20] string receives the substring at position start+1, instead of position start.
That is, when index X =1, Result =2; when X = 2, Result =3; etc.
Simple demo program attached.
Test_of_Mid$.fcfx
(3.99 KiB) Downloaded 330 times
DavidA
Has thanked: 58 times
Been thanked: 258 times
Re: Problem with Mid$
Post by DavidA »
Hi gtc,
Can you please try using the latest version of Flowcode, 6.1.2, i seem to recall an issue with some string functions were rectified in a later patch.
gtc
Post by gtc »
Seems I was a tad dyslexic when I typed the above. In fact I am using version 6.1.2.0 (11.5.2015).
If you run my sample program under debug and step through the loop while watching the variables in the simulation window, you'll see what I mean.
Hi gtc,
Since arrays start at 0 and not 1 you will need to retrieve the first character by Mid$(StringVar,0,size).
Mid$(StringVar,1,size) will start at the second char.
If you have a look at wiki help (Via Flowcode Help, Index) you will see that:
(8.51 KiB) Downloaded 3005 times
gtc
Post by gtc »
medelec35 wrote:Since arrays start at 0 and not 1 ...
Thanks. I had missed that point hidden in the example.
Matrix: please update that Wiki text entry to make clear the specific point that string arrays commence at position zero.
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
Wiki has been updated.
― C.S. Lewis
