Little bug with the dsPIC33FJ256GP710A fuses
A forums to allow bugs and problems with Flowcode v6 to be reported and resolved.
Mathy
Has thanked: 30 times
Been thanked: 33 times
Post by Mathy »
There is a little bug with the dsPIC33FJ256GP710A.
When compiling the compiler message says :
Settings in '__FGS.sec' are not valid for target device 33FJ256GP710A
But if I delete this _FGS settings, I have the same message for _FSS etc etc.
I tried with the dsPIC33FJ128GP710A and It works so I compare the fcdx and the gld file but I don't know what is wrong.
I don't know if I can use the dsPIC33FJ128GP710A instead but for the moment, it is working.
f it is possible to have a fix, it will be nice :)
Have a nice day
dsPIC33FJ256GP710A.fcfx
(4.88 KiB) Downloaded 429 times
Re: Little bug with the dsPIC33FJ256GP710A fuses
Hi Mathy,
Hmm that's a strange one I do seem to remember coming across something similar in the past. I'll look into it for you and see what we can make happen.
I have looked through the compiler files and so far haven't been able to spot anything wrong. I'll keep investigating.
Mathy
Post by Mathy »
Ok thank you Benj,
For the moment, it is not urgent because Im able to program using dsPIC33FJ128GP710A.
Good luck with this one !
Hi Mathy,
A Google search brought me back to the forums. DOH. Knew I had seen this one before.
This might help as a workaround if you need one and your program outgrows the 128 device.
viewtopic.php?f=54&t=16549
I will continue to investigate.
Mathy
Post by Mathy »
I compiled with success on dsPIC33FJ256GP710A using supplementary code with only the fuses I need :
_FOSCSEL(65529);
_FOSC(65535);
_FWDT(65407);
_FICD(65503);
Works well on real hardware 8)
Ps : testing ESP8266 :wink:
Thanks, Good to know :D
Mathy
Post by Mathy »
Hello Benj,
Just a little annoying thing.
After closing Flowcode and open again, the unticked configuration fuses becomes ticked again.
:p
Thanks Mathy,
I've put it on the list.
