USB Serial timout return value like Serial component
Please add any feature requests for Flowcode version 6 here
Forum rules
Only feature requests will be considered here. General questions should not be posted in this forum.
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
The RS232 component allows setting the return type to an integer to be able to distinguish between 255 and time-out. This feature would be useful for the USB serial component as well.
[Edit] Same request for circular buffer.
― C.S. Lewis
Re: USB Serial timout return value like Serial component
Hi Jac,
Some good suggestions there. The mods should work for both sim and download. I've also done the FAT as it could also do with it for the readbytefromfile function to signify the end of file. All component should default to the original 8-bit mode to try and ensure we do not break any existing programs.
FAT.fcpx
(64.54 KiB) Downloaded 504 times
USB_Serial.fcpx
(15.99 KiB) Downloaded 495 times
CircularBuffer.fcpx
(5.69 KiB) Downloaded 459 times
Let me know how you get on and if this is ok then I'll push the changes to the weekly build release files.
